callum wrote:yeah the plan is to buy wheels after i fit the brakes as i dont think i will be able to get my calipers within the wheels i have now. i need to find a place that can measure up my dummy hub with the new brakes and the car to make sure nothing rubs before i can buy the wheels.
matt dunn wrote:callum wrote:yeah the plan is to buy wheels after i fit the brakes as i dont think i will be able to get my calipers within the wheels i have now. i need to find a place that can measure up my dummy hub with the new brakes and the car to make sure nothing rubs before i can buy the wheels.
I would recommend buying wheel before brakes
callum wrote:sorry i ment buying new wheels after i have fit the new brakes to the dummy hub and before fitting them to the car. life would get hard real fast with no wheels that fit my car.
tsoob wrote:why?
it would be far easier to find a wheel after you have the brakes on the car as you would then know the offset and xfactor required for the car.
matt dunn wrote:tsoob wrote:why?
No,
Offset will have nothing to do with the disc, will depend on strut and guard clearance,
And different rims have the dips etc in different places, so you may find that the only rims you can get to fit are too heavy, ugly or expensive,
where if you had mounted the caliper and disc in or out a bit it would clear more options.
Only really applies if it is going to be close between the caliper and the rim,
but if it's not close then what's the point of this whole thread.???
