External Waste Gates
Postby bbq1988 » Thu Oct 22, 2009 12:33 pm
Hey guys, I'm after some info on external waste gates, what size would be best etc.
I Am planning on using an external waste gate on my RB30DET Setup, with a GT35/40 (or equivalent sized) Turbo.
I Am after 375 RWKW
Would 38mm be large enough to control the boost properly? what recommendations do you have?
Cheers.
Harley
Baked, Not Fried.
bbq1988
Postby tsoob » Thu Oct 22, 2009 3:03 pm
what manifold are you using? custom or chinese?
big power figures, you will be spending plenty of dosh to get there
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby bbq1988 » Thu Oct 22, 2009 3:15 pm
Custom manifold, Would 38mm Be large enough?
Baked, Not Fried.
bbq1988
Postby Lith » Thu Oct 22, 2009 3:22 pm
bbq1988 wrote:Custom manifold, Would 38mm Be large enough?
Pretty sure the guys I know running setups like you describe are running near 50mm wastegates...
2007 Mazdaspeed Axela
Lith
Postby bbq1988 » Thu Oct 22, 2009 3:25 pm
sweet, thanks for that mate
Baked, Not Fried.
bbq1988
Postby deaf_rattle » Thu Oct 22, 2009 3:45 pm
im going to be running a gt3540 (gt3582R) on my 3l 7mgte with custom manifold.
I have got a tial 44mm external, was told not to go too large.
Then again im aiming for less power than you.
Postby molex » Thu Oct 22, 2009 3:53 pm
More power = smaller wastegate required
If you're running ridiculous boost a 38mm would probably be fine. Turn the boost down and you could have issues. If you're spending the coin for that sort of power then I would go a bit bigger for peace of mind/flexability.
molex
Postby bbq1988 » Thu Oct 22, 2009 4:11 pm
Cheers, im looking at running between 10-20psi
Baked, Not Fried.
bbq1988
Postby d1 mule » Thu Oct 22, 2009 6:48 pm
i wouldnt bother with a 38, go straight to a 50. good mate of mine is running a 26/30 with a custom borg warner 35/40 and one of the limiting factors is the 38mm gate from memory its at a detuned 380whp
d1 mule
Postby iOnic » Thu Oct 22, 2009 8:19 pm
Postby gasman » Thu Oct 22, 2009 8:44 pm
iOnic wrote:http://forums.performancecar.co.nz/viewtopic.php?f=37&t=47193
too much to read after work but its all really logical stuff really
"What can possibly go wrong?"
gasman
Postby tsoob » Thu Oct 22, 2009 9:43 pm
deaf_rattle wrote:im going to be running a gt3540 (gt3582R) on my 3l 7mgte with custom manifold.
thats where id be looking for this setup, although im assuming that you have all the other bases covered (fuel, ecu, etc)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby iOnic » Fri Oct 23, 2009 8:04 am
Yep. If people actually bothered to read/think about how these things work then we'd have a lot less misinformation and comments such as the one below
d1 mule wrote:i wouldnt bother with a 38, go straight to a 50. good mate of mine is running a 26/30 with a custom borg warner 35/40 and one of the limiting factors is the 38mm gate from memory its at a detuned 380whp
Postby bbq1988 » Fri Oct 23, 2009 9:48 am
Cheers guys, after reading that i think a 38 or 44mm would be best for response & general control of boost.
Fueling/ECU will be sorted soon but the engine will not be going into the car until next year as i also need to purchase a gearbox that wont explode!
Baked, Not Fried.
bbq1988
Postby YeMs » Fri Oct 23, 2009 12:43 pm
i had a 46mm on a 400kw 2jzgte and that was unstable. i would go minimum 50mm.
Your local Hybrid Elite tech
YeMs
Postby molex » Fri Oct 23, 2009 1:06 pm
If you had read the above posts you might have realised that maybe it's because 46mm was too big rather than too small.
molex
Postby tsoob » Fri Oct 23, 2009 2:02 pm
bbq1988 wrote:Cheers guys, after reading that i think a 38 or 44mm would be best for response & general control of boost.
yep you are on the right track there.
38mm Tial $475
44mm Tial $845
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Fri Oct 23, 2009 2:28 pm
YeMs wrote:i had a 46mm on a 400kw 2jzgte and that was unstable. i would go minimum 50mm.
Which means the wastegate was too large and going to a 50mm would make the problem worse
Postby Lith » Fri Oct 23, 2009 3:22 pm
I'm not sure about that eh. Most cases I have seen where people have tried to control the described boost levels with GT3582Rs using 44mm or less wastegates have had issues with creep, one of my mates has a 1.06a/r GT3582R and he has been fighting boost creep with his 48mm wastegate using a Sinco manifold.
Lith
Postby sergei » Fri Oct 23, 2009 4:09 pm
Since talk of waste gates, has any one used variable geometry turbo in an aftermarket application? What do they use to control turbo? ECU output to a stepper motor?
This tech makes wastegates obsolete.
