you're saying that the turbo itself constributes to being a restriction in the intake and therefore introduces 'turbo lag' and therefore removing this 'restrictive' section, get rid of the associated 'lag' ?
fivebob wrote:One of the more interesting systems I've seen was developed by Cosworth for the WRC cars, and promptly got banned because it was so effective.
Basically it involved large pressure tanks and a couple of bypass valves, when the boost limit was reached the bypass valve opened to fill the tanks. When the manifold pressure was below the boost limit, and the pressure in tanks was higher than in the manifold, the other bypass valve opened and quickly pressurised the manifold.
Snaps wrote:I guess that's what I thought, does it not really work that way?
frost wrote:only problem was having the room to place said tanks with out it being too far away to be effective.
kim0663 wrote:So it'd be storing the tanks with ext gas?
