Replacing bushes on SW20 rear sway bar?
Postby Adamal » Tue Oct 27, 2009 8:09 am
I'm thinking of doing this, but I've had a look under there before, and at a quick glance, it looks like you'd actually have to drop the subframe to do so. IE it would be a monumental pain in the ass to do so.
Has anyone ever replaced these before and found an easy way to do it? Or is lowering the subframe etc the only way?
Postby Akane » Tue Oct 27, 2009 1:20 pm
Yeap it requires you to drop the subframe, but not by much, last time when I was messing with the bushes I got away by dropping the gearbox mount bolt, and the 4 subframe bolts (I think that's all you need?) and that'll lower the subframe enough for you to take the tabs out / bushes out.
Postby Adamal » Tue Oct 27, 2009 1:23 pm
I <3 Akane.
Postby Akane » Tue Oct 27, 2009 8:11 pm
I <3 you too
*man hug*
Postby Lloyd » Tue Oct 27, 2009 10:12 pm
Gotta drop it, no other way around it. Its not that bad to do though
