2ZZ-GE Lift Bolt issue
Postby snwtoy » Tue Oct 27, 2009 12:42 pm
Did a search on this and couldn't find anything here.
Is anyone else aware of the issue? Appears to affect 2000-2002 2ZZ-GE engines:
http://toyotaownersclub.com/forums/inde ... opic=31638
Our corolla has done 70,000 kms so I will be checking and replacing these asap.
Have just ordered from toyota for the pricely sum of $5 +gst for the two bolts.
Hopefully they're not broken, and spening half an hour replacing them will save us a 6.5 hour labour bill if they are not already broken :o
Here is the replacement procedure for replacing if broken:
http://www.everythingcelica.com/tech/ts ... tbolts.pdf
snwtoy
Postby rodstr » Tue Oct 27, 2009 10:14 pm
Hmmm, ive got a 2002 runx on 84000ks...
rodstr
Postby matt dunn » Tue Oct 27, 2009 10:32 pm
I found heaps on the net about it when I was looking at going 2ZZGTE instead of the 7AGTE.
there are a few good USA sites about it,
also known as lift pins IIRC.
There was an upgraded part available to fix it??
I'll see if I kept the web pages somewhere?
Postby snwtoy » Tue Oct 27, 2009 10:46 pm
That would be good Matt. I ordered the part from the PDF above. At least if it's the old part it'll be better than nothing.
snwtoy
Postby matt dunn » Tue Oct 27, 2009 11:30 pm
had a look but I dont have the pages saved anymore.
But it was possibly on this site,
http://www.newcelica.org/forums/index.php
or search for Monkey Wrench Racing.
Postby KinLoud » Wed Oct 28, 2009 8:21 am
Talk to Lynn Rogers - he built all the 2zzge motors for the Toyota Race series
I'm sure he will point you in the right direction.
Lynn Rogers Automotive
114 Vincent Street
Howick
Manukau City 2014
(09) 5343363
Postby kompressor » Wed Oct 28, 2009 12:58 pm
Im on well over 110,000 km and mine are fine its very easy to pull them out and check. If you want bring it over to mine and I will check them for ya!
kompressor
Postby snwtoy » Wed Oct 28, 2009 10:04 pm
kompressor wrote:Im on well over 110,000 km and mine are fine its very easy to pull them out and check. If you want bring it over to mine and I will check them for ya!
Cheers, I can probably do it myself if I don't have to take the drive belt off (always nervous about doing that)? Can you confirm you can get to them without doing this?
snwtoy
Postby kompressor » Thu Oct 29, 2009 10:03 pm
Yep just rocker cover and you can get to them
kompressor
