quick cambelt question..
Postby RS13 » Wed Oct 28, 2009 9:13 pm
Just replaced the waterpump on my 91 Laser, can't recall how tight the cambelt was, do I just let the tensioner (which is sprung) take the tension then do its' bolt up? With the tensioner alone its' quite tight.. hmm.
Cheers! :)
RS13
Re: quick cambelt question..
Postby sergei » Wed Oct 28, 2009 9:50 pm
RS13 wrote:Just replaced the waterpump on my 91 Laser, can't recall how tight the cambelt was, do I just let the tensioner (which is sprung) take the tension then do its' bolt up? With the tensioner alone its' quite tight.. hmm.
Cheers! :)
Undo the tensioner just so spring takes the slack, and rotate the crank about 10-15 degrees in normal direction (just to take off slack on other side), tighten the tensioner.
Postby RS13 » Wed Oct 28, 2009 9:55 pm
Awesome, thanks Sergei! :)
RS13
Postby Lloyd » Wed Oct 28, 2009 11:34 pm
As above, you should be able to see where the cambelt goes slack on the tensioner side and the springs tries to take the slack. Sometimes need a little bit of pressure behind them with your finger just to keep the belt tight when you're doing up the locking nut.
