4age timing help
4age timing help
Postby apprentice » Wed Oct 28, 2009 9:46 pm
i put a 4age in a ae70 it's stock apart from filter and 2"5inch exhaust aw11 bluetop Map sensor
i have been battleing with this engine for months on and off
problems are
timing doesn't advance when engine revs increase
engine only runs for a second no matter what you do when the T and E1 are shorted out
things i have tried
have tried 2 different MAP sensors
replaced plugs
checked TPS
and tested MAP TPS wiring from plugs to ecu
Thanks
apprentice
Postby tsoob » Wed Oct 28, 2009 10:17 pm
you replaced the cas or dizzy?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby apprentice » Wed Oct 28, 2009 10:37 pm
tsoob wrote:you replaced the cas or dizzy?
no neither
apprentice
Postby matt dunn » Wed Oct 28, 2009 11:02 pm
Dont really understand what you are saying?
How do you know the timing doesn't advance when you rev it,
when the car wont run?
Postby apprentice » Wed Oct 28, 2009 11:09 pm
matt dunn wrote:Dont really understand what you are saying?
was trying to do the timing and revd it with timing light still on and the timing stayed at what it was at idle speed
thanks
apprentice
Postby apprentice » Fri Oct 30, 2009 7:22 pm
turned out to be burnt out ecu
apprentice
