Coolant blocking radiator?
Postby pc » Sun Nov 01, 2009 6:46 pm
Heres a question for radiator people.
I've got a radiator that I had re-cored about 5 years ago for the race car (it's copper). There have been a number of engines in the car over the years but they have all been flushed well or clean rebuilds, so no rust or other foreign bodies floating around in the coolant.
The radiator fan is on all the time as I removed the aircon and some aircon switch is missing now, so the fan stays on, doesn't really bother me as it's a race car anyway.
I found my water temp going up the other day and after some testing I have found that there is no water flowing through the radiator at all around where the fan mounts (about 1/2 the radiator) and as it is where the fan mounts, the fan is doing no good. The other 1/2 of the radiator seems to work fine.
Is it possible to over-cool coolant and make it congeal in the radiator?
I'm using the Repco Anti-Freeze/Anti-Boil coolant which says it is mostly ethylene glycol.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Re: Coolant blocking radiator?
Postby ee904age » Sun Nov 01, 2009 7:35 pm
Logic would say no, as it's designed to be used in sub zero temperatures as an anti-freeze....
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby rollaholic » Mon Nov 02, 2009 6:46 pm
maybe if you are racing in the arctic?
