Mr Revhead wrote:your looking at about $3-500 a corner just for the parts to convert a normal strut to adjustable platforms
not including new shocks
Mr Revhead wrote:i mean the parts needed to convert stock shocks to adjustable platform shocks.
On re-reading your first post, do you mean welding the strut body onto the lower casting? the bit with the two arms that link to the hub and lower arm?
nz_climber wrote:Stocks in Mt Wellington are able to convert a shock into an adjustable coil over.. Depends on the shock thou as some shocks are to thin to weld safely etc. its not cheap thou, adds up pretty quickly as you need springs to suit new platforms too.
Also got to ask, whats the reason for adjustable shocks and platforms, pretty overkill and expensive (remember cert etc too) for just a street car...
ihavelift wrote:nz_climber wrote:Stocks in Mt Wellington are able to convert a shock into an adjustable coil over.. Depends on the shock thou as some shocks are to thin to weld safely etc. its not cheap thou, adds up pretty quickly as you need springs to suit new platforms too.
i want to do a few track days. And i'm getting really confused here, can't i just buy a set of adjustables (shocks, springs and all the sh*t that comes with it) and that'll be all the parts i need? what do you mean by converting shocks into adjustable coil overs?
Mr Revhead wrote:ihavelift wrote:nz_climber wrote:Stocks in Mt Wellington are able to convert a shock into an adjustable coil over.. Depends on the shock thou as some shocks are to thin to weld safely etc. its not cheap thou, adds up pretty quickly as you need springs to suit new platforms too.
you were talking about welding things etc
as in your wanted to make your own....
Mr Revhead wrote:you were talking about welding things etc
Mr Revhead wrote:I have no idea what they mean by that
shouldn't need any welding at all
nz_climber wrote:I am with Revhead - they if they designed for your car they should just bolt straight up..
ihavelift wrote:the OEM shocks and new springs will definately be cheaper, but surely adjustables will improve handling exponentially?
