bbq1988 wrote:Hey guys,
Can someone fill me in on the pro's & cons of the Split pulse setup?
Turbo in question to make the manifold for is possibly a Holset HX40 (Super40)
thegreatestben wrote:As mentioned but 200cc wouldn't make as much of a noticable difference as there is. The corolla has a much better link/tune/ignition too.
Twinscroll is FTW in my application anyway
mjrstar wrote:I was wondering about cam selection/timing with twin scroll turbos. As scavenging can be quite as complete as an open scroll, do you need to compromise and have less aggressive cams and cam timing to ensure a decent scavenging effect.
I guess the flip side is you can go larger in the exhaust hsg AR on a twin scroll and have similar boost response to a smaller open scroll housing?
I'd really like to see some back-to-back runs on twin vs single scroll as I'm seriously considering a twin scroll setup as I’m happy with the moderate power level of my 2 litre at 245kw but would love to get boost on a few RPM earlier.
steve murch wrote:split pulse can improve response but kills horsepower.
and well designed exhaust open scroll turbo will perform better all round.
if you want good response and power then open scroll, remember when doing a pulse tuned exhaust you increase the turbine back pressure that's why you gain a little more response,back pressure hurts power.
Lith wrote:steve murch wrote:split pulse can improve response but kills horsepower.
Hi Steve, thats quite interesting.
What is it about split pulse housings that can kill horsepower?
Do you have any theories on that thread I linked to where a chap I know with a 300ZX swapped from a single entry turbine housing to twin scroll, with modifications to manifold to suit ended up with both better power and better spool?
steve murch wrote:Lith wrote:steve murch wrote:split pulse can improve response but kills horsepower.
none of this is a theory, its well documented threw people like SAE and Owens developments in England who build allot of the turbos for WRC and they detest the split pulse for making power.( feel free to question these people )
the problem is the divider cuts off nearly a 1/4 of the feed to the turbine wheel thrus increases back pressure reduces horsepower.
as for what your mates done from memory the old zed ran a split pulse manifold and open scroll hsg so with what hes done with mods to which i gather is extensive porting hes picked up performance as the stock setup was very poor to start with.
and if what Barry has written above if hes talking about mike delmonts bmw, i know for fact he doesn't run a split pulse turbine as i helped do his last setup to which feel free to ask mike but im sure your dad knows how to get hold of him.
if its not him and its a 2.3 pinto they love big turbos and responed well wether its a split or open, kane scotts merker is a prime example of that.
i apologise is either of above is wrong barry.
also going to any increase in displacement will improve response thats why its done ( cant bet more cub's ) since your making more exhaust energy it goes hand in hand.
there is allot of people who use pulse tuned headers and get good results,im talking about making more horsepower and still have response.
the motor that barry's dad had to rebuild again( his dad knows why) for a very good mate of mine was changed from split to open brought boost on 1000rpm sooner and picked up a good increase in torque.
as with above long runs can make you more power thats why its done but generaly they arent split pulse and still the tuned length is worked out in relation to whats needed, cams head flow compression intake etc etc all come into it.
so i guess its what works best for you and if you get the numbers then its well worth doing.
Bazda wrote:steve murch wrote:Lith wrote:steve murch wrote:split pulse can improve response but kills horsepower.
Interesting. He told me last time I talked to him he was running a split pulse :S.
Must of said the wrong thing I guess.
I see him every weekend down at the workshop, I will ask him again.
steve murch wrote:none of this is a theory, its well documented threw people like SAE and Owens developments in England who build allot of the turbos for WRC and they detest the split pulse for making power.( feel free to question these people )
Lith wrote:steve murch wrote:none of this is a theory, its well documented threw people like SAE and Owens developments in England who build allot of the turbos for WRC and they detest the split pulse for making power.( feel free to question these people )
I wasn't talking about the single being better than split pulse being a theory, I was asking why the guy with the Z got gains. It was a twin turbo Z that was converted to single turbo - if you read the thread it always had custom manifolding for the turbo setup, he tried 2/3 single scroll turbos on it and never got a satisfactory result.... went to a twin scroll one and all his problems went away.the divider cuts off nearly a 1/4 of the feed to the turbine wheel thrus increases back pressure reduces horsepower.
Yeah thats the bit I was always dubious of, I would love to have access to such things to play around with - now there are a few people I find very credible completely contradicting each other haha. Most TS setups I have READ (yes, not experienced...) about have dropped turbine pressure and been able to take more timing. I know only one person in real life who has done the change from twin to single scroll and that was also his experience which did sway me a bit, I have to admit.... though have noticed things like the TR30R and IHI RX8 seem to come in very fancy looking single entry layouts.
So much to learn....
