strx7 wrote:it will be the laggiest set up possible after changing gears because when the BOV opens all the pressurised air between it and the throttle body back feeds to vent out the BOV. when the BOV closes you then need to pressurise up all the volume between the bov and the throttle body before you are back into boost
fivebob wrote:Should be fine, that's the stock SW20 set up and there are no issues with it even when using much larger turbos
FLAWLES wrote:std vvti 1jzgte factory bov is straight after the turbo ( well on that big stupid manifold )
back feeds into the plenum type set up
and thats where my new aftermarket one will be going
loudstealthGT-Four wrote:Read somewhere that the closer the bov is to the throttle body the better the response and the closer it is to the turbo the louder it is? True or BS
fivebob wrote:strx7 wrote:it will be the laggiest set up possible after changing gears because when the BOV opens all the pressurised air between it and the throttle body back feeds to vent out the BOV. when the BOV closes you then need to pressurise up all the volume between the bov and the throttle body before you are back into boost
That doesn't make sense:?
Location makes no difference to the volume of air that the valve vents, and that is the air the will have to be "replaced" when the valve closes again, therefore there should be no detectable difference in lag.
strx7 wrote:With the BOV by the turbo, the intake charge is like a wave at the beach, back and fowards, with it by the throttle body, its like a stream. the intake charge keeps flowing in the right direction
Coke wrote:FLAWLES wrote:std vvti 1jzgte factory bov is straight after the turbo ( well on that big stupid manifold )
Will it be a plumb back? I hear they run like shite if using a bov that vents because of the afm....ive got a vvti 1jzgte and thought about going aftermarket.
