gtt 3sgte head bolt torque?
Postby blitza » Mon Dec 07, 2009 7:49 pm
so i've searched, i know it's x+90deg+90deg, but can't remember what x is. nor can i find my workshop manual. Booo. (yes, i have new bolts)
MAD Industries Limited
blitza
Postby Akane » Mon Dec 07, 2009 8:48 pm
if you fail to find one for the GT-T,
the spec according to mr20c the for Gen 2 is 36ft/lbs.
the spec according to my BGB for Gen 2 is: 500kg-cm (36 ft-lb, 49 N-m) + ONE 90 degree tighten, not 2.
do the 90 degree tighten *AFTER* you've tighten all the bolts to 36 ft-lb in the correct order.
Postby Anth_555 » Tue Dec 08, 2009 7:27 am
what Akane has said is same for a gen 3
-1994 GT4 Celica ST205 project
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
