Caldina GTT questions
Postby madaz-gtt » Tue Dec 15, 2009 9:22 am
Hi guys,
Im new to this forum and im hoping someone here can help me out with a couple of questions i have.
Ive just brought a caldina gtt and want to install a boost tap on it, when i was looking at the stock wastegate i see they run two pressure sources almost like an aftermarket one, which line do i run the tap on? the line that runs from the turbo to the side of the wastegate or the other that runs from the top to im guessing the intake?
Also whats the maximum boost the car can handle safely with only a 3" exhaust and pod filter? i was thinking 12psi?
any help would be much appreciated.
madaz-gtt
Postby MR2BOY23 » Tue Dec 15, 2009 9:32 am
Im thinking its the one between the turbo and wastegate.
MR2BOY23
Postby bbq1988 » Tue Dec 15, 2009 9:36 am
12psi should be fine, they usually run 12-14psi factory. Dont put it up any more then 14psi if you dont want to buy a new motor :-)
Baked, Not Fried.
bbq1988
Re: Caldina GTT questions
Postby fivebob » Tue Dec 15, 2009 9:45 am
madaz-gtt wrote:Also whats the maximum boost the car can handle safely with only a 3" exhaust and pod filter?
Stock boost, so why bother with a boost tap ;)
Which is the stock boost level.
Postby MR2BOY23 » Tue Dec 15, 2009 9:49 am
Boost guage should be the first thing you get
MR2BOY23
Postby madaz-gtt » Tue Dec 15, 2009 9:58 am
cool thanks for your help. ill prob run 14 if it can handle it then ill see how i go. ive got a boost guage already and it reads ruflly 11, wanted to put the tap in to make a bit more consistant.
so you reckon it is the pipe between the turbo and gate? makes sense just needed to be sure.
another question i had was when its idling i can hear a fan ticking noise coming from behind the glove box where the Ac and heater system is, it goes away when i rev but its damn annoying to listen to, anyone got any ideas what it could be or how to fix it?
madaz-gtt
Postby cedwards » Fri Dec 18, 2009 8:36 am
try listening to your BOV (bolts into airbox) quite common for these to tick on idle when it is working as a turbo bypass valve
cedwards
Postby strx7 » Fri Dec 18, 2009 12:48 pm
if you stick a boost tap on it, keep this number handy, 0800 100 494. and call me when your engine blows (not if), and i'll suss you out a deal on a replacement.
otherwise leave it at std boost level.
Postby madaz-gtt » Sat Dec 19, 2009 5:42 pm
yea ive figured the ticking noise is the vacuum hose that hooks into my boost guage, when removed the noise goes. replaced the pipe and the noise comes back. ive got a hks squential bov installed which is run off a T piece with the bov, could this cause the ticking noise?
i was thinking the hose could be split but unlikely for it to happen twice.
haha cheers for the number had a bit of bad luck with the car, currently getting the front axles replaced so i think ill be leaving it all stock.
anyone in auckland no of a good wrecker where i can get some good condition door trims?
cheers guys
madaz-gtt
Postby cat007 » Sun Dec 20, 2009 9:18 am
welcome to the forums
a boost tap is not going to give you a more stable boost pressure. It will just make it works.
Get a proper electronic boost controller and DON'T run it over 14psi unless you've got a spare 3S handy?
Postby madaz-gtt » Mon Dec 21, 2009 2:56 pm
cheers yea ill be leaving the boost alone now.
is there any common faults with the gearboxes in theses? mines started making a clicking sound when driving in a straight line. ive taken it to adl thinking it was the cvs or axle. he did some work to the axle and said the cvs are fine and that its prob the box / transfer case. any ideas what it could be?
anyone know a good toyota mechanic in auckland?
madaz-gtt
