Polyurethane engine mounts
Postby Jdawg » Tue Dec 15, 2009 3:29 pm
Anybody know if there is someone in NZ making polyurethane engine mounts.
Curren needs a new rear mount
Jdawg
Postby MR2BOY23 » Tue Dec 15, 2009 3:32 pm
autolign can make them for you
MR2BOY23
Postby levinguy » Tue Dec 15, 2009 4:06 pm
MR2BOY23 wrote:autolign can make them for you
and plus plastics in east tamaki will do them alot cheaper :wink:
if you take your old one in that is
levinguy
Postby Akane » Tue Dec 15, 2009 4:22 pm
If you can't find a mount for your car, you can always fill your old one with urethane. I did it to my MR2 mount and it stiffens things up quite a bit, great for someone who want to try things out.
Postby neo » Tue Dec 15, 2009 4:24 pm
http://forums.toyspeed.org.nz/viewtopic.php?t=72915&highlight=urethane
http://forums.toyspeed.org.nz/viewtopic.php?t=71642&highlight=urethane
And there is 'The Mount Shop' in auckland 09-579 5965 , that can do replacement mounts - Double edit - and they supply via Partsmaster
neo
Postby Bazda » Tue Dec 15, 2009 8:50 pm
Plus Plastics in east tamaki. $30-40 per mount to be refilled with Urethane witht he old mount burnt out.
Cheaper if you only want to leave the stock rubber in there and fill over it.
Postby Jdawg » Tue Dec 15, 2009 9:23 pm
Cheers for replies. Car is getting recomplied so will check if they will allow Urethane mounts first.
Just the rear mount from Appco is $160+
Jdawg
Postby molex » Tue Dec 15, 2009 9:47 pm
Bazda wrote:Plus Plastics in east tamaki. $30-40 per mount to be refilled with Urethane witht he old mount burnt out.
Hate to break it to you Bazda but their prices must have gone up.. last quote I had a month or two back was $60 each for small fwd mounts.
I ended up buying the urethane and doing it myself, $90 kit ended up doing 6 mounts with some to spare. Some I removed all of the rubber and poured it completely from urethane, some I left the stock rubber intact and filled in around it. Both worked very well. I used 80a shore rated stuff, if you leave the rubber intact they are very streetable.
molex
Postby Bazda » Tue Dec 15, 2009 10:24 pm
Ohh bugger then. I havent been there in a while.
Postby Jdawg » Thu Dec 17, 2009 9:16 pm
4 mounts to Plus Plastics, get them back on 23rd, around 60 each but they had to burn the old rubber out as I was a bit pushed for time so will clean out the next set for a bit cheaper.
and still lots cheaper than buying rubber replacements
Jdawg
Postby Santa'sBoostinSleigh » Fri Dec 18, 2009 10:20 am
molex wrote:I ended up buying the urethane and doing it myself, $90 kit ended up doing 6 mounts with some to spare. Some I removed all of the rubber and poured it completely from urethane, some I left the stock rubber intact and filled in around it. Both worked very well. I used 80a shore rated stuff, if you leave the rubber intact they are very streetable.
where do you get that stuff from?
pretty easy to do, and work sweet?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby DeeCee » Fri Dec 18, 2009 11:43 am
tip: use ice to smooth off the urethane ;)
GT Four Adovansu
DeeCee
Postby cat007 » Fri Dec 18, 2009 11:56 am
Where did you buy it from?
Postby molex » Fri Dec 18, 2009 2:03 pm
Bought from here:
http://www.topmark.co.nz/articlelive/ar ... hanes.html
Lovely lady. Offers a discount for students, didn't help me sadly.
molex
