plug on PS rack ae101
Postby soopachargen » Thu Dec 17, 2009 10:55 pm
when i was pulling my motor out i forgot to disconnect the wires going from my engine loom to the steering rack and they pulled out of the plug, does it matter which way round they go back in or can i just make it up as i go along?
When in doubt, down and out.
soopachargen
Postby themaleman » Fri Dec 18, 2009 8:01 pm
what car/engine?
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby soopachargen » Fri Dec 18, 2009 10:37 pm
ae101 gt sedan with silvertop running silvertop loom and blacktop computer, throttles, map sensor and IAT
soopachargen
Postby AE25 » Mon Dec 28, 2009 11:16 am
does the PS rack also have two air hoses going to the throttles?
if not, then i believe this could be the electronic pressure sensor. but i dont know whether its just a switch to turn on an idle up (any way round for the wiring) or something more complicated.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby soopachargen » Mon Dec 28, 2009 12:32 pm
it's got the two vacuum lines as well, i figured it may be some sort of pressure switch for when the PS is under the most load to raise the idle
soopachargen
Postby AE25 » Mon Dec 28, 2009 2:01 pm
maybe, might be ecu related?
but thats what the vacuum hoses do.. the pressure valve on the rack opens when there's higher oil pressure in the rack.. which bypasses air around the throttles and raises the idle.
E2 & E7 fanatic
AE25
