VVT solenoid
VVT solenoid
Postby Dell'Orto » Mon Dec 21, 2009 12:53 am
Just in the process of lifting the motor out of the Levin for a bit of a birthday...when unplugging the VVT solenoid, I noticed the plug can move side to side quite freely. Is that normal? :?
Also I $&#$% hate where the knock sensor is, honestly what a prick to undo :lol: Stupid $&#$% 20v's..
Postby sergei » Mon Dec 21, 2009 8:41 am
It is probably coil loose, should not affect performance of the solenoid overall.
Postby YeMs » Sun Jan 03, 2010 5:41 pm
yeh iv noticed with quite a few vvt solenoids they wiggle back and forth quite freely like that. have never noted a running issue though..
Your local Hybrid Elite tech
YeMs
Postby Bazda » Mon Jan 04, 2010 3:02 pm
yep they all will do this as the metal housing presses the solenoid together against an O-ring to seal the oil from coming out.
