crank button
crank button
Postby deaf_rattle » Thu Dec 24, 2009 2:09 pm
Is it possible to have a crank button with a stock ecu set up?
basically, it would be nice to have a crank only button to make sure i have oil pressure before engine start up.
Or is this too difficult?
Re: crank button
Postby sergei » Thu Dec 24, 2009 2:35 pm
deaf_rattle wrote:Is it possible to have a crank button with a stock ecu set up?
Very easy, just don't one the wires in the ignition switch (will have to find it experimentally), like a "ignition override" push button.
Postby Lloyd » Thu Dec 24, 2009 5:59 pm
Just wire a wire to the starter... easy
But why?
Postby Dell'Orto » Thu Dec 24, 2009 7:09 pm
If you're worried about oil pressure for the first time starting, see if you can borrow a pressure primer from an engine reconditioners. Just hook it up to a little compressor, and wind about 30psi into it
Postby Lloyd » Fri Dec 25, 2009 9:50 am
Just unplug coils, take plugs out and wind it over on the key if its just initial start up. If you want it for every other time you start the car then there are other issues I think need addressed
Postby IH8TEC » Fri Dec 25, 2009 11:06 am
Lloyd wrote:Just unplug coils, take plus out and wind it over on the key if its just initial start up. If you want it for every other time you start the car then there are other issues I think need addressed
2nd'd
Postby Malcolm » Sat Dec 26, 2009 12:18 am
it's not a bad idea if your oil system has long lines running to say a remote filter and oil cooler to crank the engine slowly to get oil pressure before it starts up.
A bit of piece of mind and very easy to do, all you need to do is wire a momentary switch in parallel with the ignition switch (just the part that triggers the starter). Then you just press the button before you turn the key on, although you wont get the oil pressure light on the dash, so a better option might be to have a switch to kill power to the ECU so you can crank normally but it wont inject or fire.
Postby headshotnz » Sat Dec 26, 2009 12:26 am
On the ignition loom splice the constant 12v wire and splice the starter motor wire, buy a button or switch, which ever you prefer from say dick smiths. wire it in, easy as pie, plus have a fiddle round. learn how to hotwire a car :D
(not necessarily directed at TC as im sure most people on here know what im talking about..)
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby AE25 » Sat Dec 26, 2009 12:30 am
yep unplug injectors, remove spark plugs... crank engine with key until happy.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby Bazda » Sat Dec 26, 2009 8:51 am
Unplug fuel pump relay (if its easily accessible), unplug ignitor.
This way you dont need to loosen off the spark plugs. But you dont want to be cranking for over like 30s as prob not too good for the battery etc.
But if your priming the enigne for its first time then I suggest taking out the spark plugs.
Postby pureadrenalin » Sat Dec 26, 2009 3:34 pm
or get an acusump.
solves other problems too.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together
pureadrenalin
Postby deaf_rattle » Sun Dec 27, 2009 9:45 am
pureadrenalin wrote:or get an acusump.
been looking at accusumps for awhile, but yeah might wait until i get the car certed and recover from the expenses so far.
Postby levinguy » Sun Dec 27, 2009 9:54 am
how about you get an oil pressure switch (one that lights up the 'your screwed' oil pressure light on the dash) and run that off a relay so your ecu doesnt get power until you've built up that pressure
levinguy
Postby cat007 » Sun Dec 27, 2009 10:41 am
Get a Stinger ECU!
Put foot on gas above 90% to disable fuel and IG circuits.
Crank engine for however long you require
Release throttle
Engine starts
Done!
Postby cat007 » Sun Dec 27, 2009 10:42 am
Actually on a second note
I get very little oil pressure while cranking
Not enough to make much of a difference at least.
Maybe the 7M's different?
Actually - IIRC the 7M is a low pressure, high volume oil system?
Postby Malcolm » Sun Dec 27, 2009 1:32 pm
cat007 wrote:Get a Stinger ECU!
Release throttle
Engine starts
Done!
almost all aftermarket ECUs do that
