Speedometer problem
Speedometer problem
Postby Wolf_Tm250 » Sun Dec 27, 2009 10:05 pm
Hi All!
On a friend's ST205 is happening something VERY strange...
the speedometer indicates almost half the real speed.
We changed everything... tried 2 speedo gauges, changed the gbox sensor, controlled the plastic gbox wheel... everything is fine, checked or changed new!
But it still shows almost half the real velocity!
8O
Thanks...
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Sun Dec 27, 2009 10:14 pm
Almost half, or is it about 0.63 of the real speed?
Has it ever read correctly?
Postby Wolf_Tm250 » Sun Dec 27, 2009 11:45 pm
Hi Callum!
fivebob wrote:Almost half, or is it about 0.63 of the real speed?
YES !!!!!!!!!!!!!!! :D
My friend told me it was right years ago...
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Sun Dec 27, 2009 11:57 pm
Then it seems likely that someone has converted it to MPH. They probably used a divider circuit on the instrument cluster, or inline between the sensor and the cluster.
Postby Wolf_Tm250 » Mon Dec 28, 2009 12:05 am
fivebob wrote:
Wolf_Tm250 wrote:Hi Callum!
Converting to MPH would make the gauge to increase slower ?
End velocity of instruments (kmh or mph) won't be the same velocity ?
I mean 280kph and corresponding value in mph?
Moreover, all was fine till 2 years ago, and suddendly happened this issue without any external action...
I was thinking about a problem in the signal, or a missing/broken wire, or a earth problem...
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Mon Dec 28, 2009 12:12 am
Wolf_Tm250 wrote:Converting to MPH would make the gauge to increase slower ?
Converting to MPH would make the gauge read 100 when the actual speed was 160km/h. It's commonly done on import vehicles in the UK.
Very odd :? Have you tried changing the cluster or just the speedo?
Unlikely, because the signal is square wave digital signal that is converted to analog by the electronics in the cluster.
Postby fivebob » Mon Dec 28, 2009 12:25 am
Does the odometer register the distance travelled accurately?
Postby Wolf_Tm250 » Mon Dec 28, 2009 3:04 am
Ah ok, understood what you meant!
No, no divider installed...
Very odd :? Have you tried changing the cluster or just the speedo?[/quote]
Both...
Ok...
so either the sensor (new) is giving abnormal square wave signal, or there is something strange in the analog conversion...
The odometer register less distance accordingly...
Thanks!
Wolf_Tm250
Wolf_Tm250
Postby gasman » Mon Dec 28, 2009 9:45 am
if it has been configured to be in MPh you could get one of those speedo corrector kits from jaycar to bump it back up.
"What can possibly go wrong?"
gasman
Postby Wolf_Tm250 » Mon Dec 28, 2009 10:10 am
gasman wrote:if it has been configured to be in MPh you could get one of those speedo corrector kits from jaycar to bump it back up.
I don't think so...
the car is always been in Italy, and always used by the same owner!
And the issue appeared unexpectedly..
It's a real mistery...
Bye
Wolf_Tm250
Wolf_Tm250
Postby fivebob » Mon Dec 28, 2009 10:11 am
Don't know if they have JayCar in Italy :lol:
Postby 79rolla » Mon Dec 28, 2009 10:54 am
they havent changed tyer size? altho that would need to be signifcant change is size to get that, also hasn't had a gearbox/diff change thats stuffed up the ratios?
past: AE82 FXGT
79rolla
Postby Wolf_Tm250 » Mon Dec 28, 2009 8:28 pm
79rolla wrote:they havent changed tyer size? altho that would need to be signifcant change is size to get that
Yes, but it's a homologated measure (within stock +/- 3%).
Moreover the car always had this measure (235/40-17), even when the speedo was ok...
No... stock ST205 gbox...
Bye
Wolf_Tm250
Wolf_Tm250
Postby gasman » Mon Dec 28, 2009 9:11 pm
Oh real? gutted to be living in Italy then :lol: .
could always try running a new wire from the sensor to the dash in case its a loose wire or something similar.
gasman
Postby iOnic » Mon Dec 28, 2009 9:22 pm
Check resistance of speedo sensor wires and compare to another ST205?
Postby fivebob » Mon Dec 28, 2009 10:20 pm
iOnic wrote:Check resistance of speedo sensor wires and compare to another ST205?
It's a digital signal, not analog, resistance is futile :lol:
Postby fivebob » Mon Dec 28, 2009 10:26 pm
Wolf,
Have you got access to an oscilloscope, or a multimeter with a logic counter?
If so you could compare the output of the speedo drive at the gearbox to the input at the gauge cluster. If there's no difference, and the frequency is the same as your ST205 at the same speed, then the problem must be in the gauge cluster circuit that does the digital to analog conversion.
If the frequencies are the same at the two locations, but different to your ST205 at the same speed, then the problem lies with the speed sensor or the mechanical drive to the sensor.
Postby matt dunn » Mon Dec 28, 2009 10:47 pm
fiveborg wrote: resistance is futile :lol:
Checking resistance will however, tell you if there in an intercepter or something in the system.
We had a problem with an MR2 that after a year or so the speedo stopped,
and traced it to a speed Cut defender that the wire had come off, that the customer did not know was there.
It may have had something fitted by a previous owner that has failed,
or has just started working.
Out of interest, on the face does it have written KMH or MPH?
Dont know what they use in Italy?
Postby iOnic » Mon Dec 28, 2009 10:59 pm
Measuring resistance and comparing to base readings from another ST205 however will confirm if there are devices fitted inline or anomalies in the wiring between the sender and cluster. Once you've ruled that out you can look at the cluster or sender individually even though it's doubtful that either of these are the problem given that multiple replacements haven't resolved the issue.
Postby Wolf_Tm250 » Tue Dec 29, 2009 7:00 am
Yes, I could try this... thanks!
Wolf_Tm250
Wolf_Tm250
