Installing Air Horns
Postby celica_xr9145 » Mon Dec 28, 2009 11:21 pm
I got a set of duel air horns for xmas for a bit of fun for my Celica GTR 4WS ST183. Just have a few questions before i install them tomorrow.
1. Are they legal?
There not musical ones, just a single tone.
2. Do i wire them so they go off with the factory horn, can i replace the factory horn with the air horns or do they need to be wired to a seperate switch?
3. What are the basics of wiring it in? (Instructions are pretty much useless as always)
It comes with the 2 trumpets, compressor and a relay.
4. It doesn't come with any wires so what gauge wire shall i be looking at getting?
Sorry for the sh*t load of questions, would rather do it right first time 8)
celica_xr9145
Postby Bling » Mon Dec 28, 2009 11:34 pm
1. Are they legal?
Yes
I wired mine to a seperate switch on the dash so no old lady has a heart attack when the WOF inspector checks my horn. Plus I reserve the air horns for REAL w**kers, not just everyone I toot at :lol:
Google for wiring air horns, will be plenty of info out there. They usually come with a basic diagram which is all ya need.
Not sure, I used wire I had lying around, someone else will know. Bigger wire will be better than smaller wire. Mainly on the 12v supply to the compressor though.
Postby Lloyd » Mon Dec 28, 2009 11:36 pm
They're legal, can be used with or without factory horn
Easier way is to use the original wiring to the original horn, disconnect that and use it to switch the relay for the air horns. Wire should be anything rated at around 20A to comfortably cover it. Wiring it up will depend if your horn button supplies power or earth to the factory horn.
In either case, if you can sort out how a relay works then you should be able to work it out.
Other wise just ask, they aren't that complicated to wire up
Postby celica_xr9145 » Tue Dec 29, 2009 12:00 pm
Thanks for the replies, have just started now.
One thing i dont understand is how to make it go off with the original horn.
Do i have to tap into the electrical wire that goes to the original horns?
Also, to get the power, do i have to tap into the main horn fuse?
Also, would you recommend upgrading the fuse from a 15A to a 20A?
The main problem at the moment seems to be finding room to mount the trumpets and the compressor :?
celica_xr9145
Postby Dell'Orto » Tue Dec 29, 2009 12:28 pm
Should make it reasonably clear (I hope :lol:) With pin 86, you should just be able to unplug the wire from your current horn and plug it onto the relay. Unless you're wanting to run both, then just tap a feed off it...your horn button should supply power I think.
Postby 20v_rollaboy » Tue Dec 29, 2009 12:35 pm
Yea horn wire normally supplies power, as is grounded by being bolted down.
Pic of my setup:
20v_rollaboy
Postby jakesae101 » Tue Dec 29, 2009 1:01 pm
nice bit of tps in that install
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby solitaire » Tue Dec 29, 2009 1:03 pm
20v_rollaboy wrote:Yea horn wire normally supplies power, as is grounded by being bolted down.
Pic of my setup:
F^&K Me wouldn't want to p!ss you off with my windows down :lol:
AE92, KZJ120, KDJ120
solitaire
Postby Nuty|Mike » Tue Dec 29, 2009 1:36 pm
dont have the horns pointing up on install I learnt that the hard way with more gurgling then beepeng after a good downpour. :lol:
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Bling » Tue Dec 29, 2009 1:46 pm
LOL two compressors for 3 horns 8O
I'm guessing that dent in the chassis is from the horn :lol: :lol:
Postby Alex B » Tue Dec 29, 2009 1:53 pm
Farking LOL at TPS. :lol:
Keen for some roof mount train horn action my self.
Postby 20v_rollaboy » Tue Dec 29, 2009 5:20 pm
I actually tried a horn from a truck, but needed too big of a compressor so make it work :lol:
TPS is all good :lol: All I had at the time.......
20v_rollaboy
Postby celica_xr9145 » Tue Dec 29, 2009 11:31 pm
Thanks for the diagram Dell'Orto, simplified things loads!
Its all in and wired up and well, its loud.
Only problem is that i've mounted the compressor behind the bumper but is visible once you lift the bonnet. You can even see a little bit through the carbon fibre strips.
Do you think it would be alright leaving it there or do you think its too much of a risk getting it wet?
Problem is that the engine bay is quite packed so there isn't much room. Unfortunatly i couldnt use the factory horns due to needing the holes for the trumpets. :?
celica_xr9145
Postby Bling » Wed Dec 30, 2009 9:08 pm
Spray it black if you want to hide it, and don't drive in DEEEEP puddles and it will be fine with the odd bit of rain.
Postby Crampy » Thu Dec 31, 2009 1:31 pm
My mate had a train horn on the bonnet of his Landrover. It was extremely loud, oh yeah!
Crampy
Postby 79rolla » Thu Dec 31, 2009 1:55 pm
http://www.youtube.com/watch?v=BGYcnYLK_50
:lol:
i wanna see if i can get my hands on a fog horn :twisted:
past: AE82 FXGT
79rolla
Postby celica_xr9145 » Thu Dec 31, 2009 2:24 pm
That youtube video is awesome! :lol:
Crampy wrote:My mate had a train horn on the bonnet of his Landrover. It was extremely loud, oh yeah!
I bet it wasnt as loud as this :lol:
http://www.youtube.com/watch?v=sPwhr-5HPb0
celica_xr9145
Postby Crampy » Thu Dec 31, 2009 7:34 pm
celica_xr9145 wrote:That youtube video is awesome! :lol:
:lol:
Holy shitbags!!!
No , it wasn't as loud as that, but it was probably near that size though. Was funny as.
Crampy
Postby Crampy » Thu Dec 31, 2009 7:38 pm
79rolla wrote:http://www.youtube.com/watch?v=BGYcnYLK_50
:lol:
That's a sweet horn.
Crampy
Postby Alex B » Fri Jan 01, 2010 3:11 pm
http://www.youtube.com/watch?v=JEfYnByuTQ0
No, no THIS is a sweet horn.
