Please help! Changing rear brake pads...
Postby Rusteee » Thu Dec 31, 2009 9:19 am
I am changing the rear brake pads on a 97 Trueno AE111, and I cant get the pistons to push back in, to allow the new pads to fit.
I was using a "C" clamp and the old brake pads but it wouldnt budg. Is there something else I have to do before the piston will push back in??
Rusteee
Postby levinguy » Thu Dec 31, 2009 9:32 am
not sure about the ae111, but some of them have to be wound back in, as in spun clockwise as they're pushed in.
levinguy
Postby Bazda » Thu Dec 31, 2009 10:25 am
you need to turn them to push them back in.
You can either use a special tool, and sometimes long nose pliers work.
Postby iOnic » Thu Dec 31, 2009 10:33 am
Repco sells the tool you need. Goes onto a 3/8" ratchet and winds the pistons back in - only takes a few seconds to do and definitely well worth the ~$20 pricetag
Postby Rusteee » Thu Dec 31, 2009 11:36 am
Legend!! lol I can't believe I didn't think of that x]
Cheers for the help guys, got the new pads in, didn't realise my old ones were that bad :?
Rusteee
