Thread damage
Thread damage
Postby thornz » Thu Dec 31, 2009 4:07 pm
In the past few days we have been replacing the hose from hell on my mr2. Have finally got the hoses replaced, so thought we were on the way to an early victory. Now, when reassembling the oil cooler and relief valve, it appears we have cross threaded it, only the at the very start, the first ring pretty much. So now we cant screw it back in.
What do we do to fix this? Can we push through it should sort itself out being that its only the first thread or so? Or will it need re tapping?
thornz
Postby jakesae101 » Thu Dec 31, 2009 4:11 pm
go buy a thread file of the correct thread pitch and it will restore the thread
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby rollaholic » Thu Dec 31, 2009 4:33 pm
if its the male section you've damaged you can try what jake has suggested, though it depends on how bad it is. i've had limited success with thread files myself, die is much better.
for what its worth i always try and get those unions started by hand first, at least a couple of turns so you can be sure its not cross threaded.
if its the female section you definitely want to tap it before trying to put it on again.
Postby thornz » Thu Dec 31, 2009 5:31 pm
It looks like only the female end is damaged, the male end looks fine.
thornz
Postby Phothog » Thu Dec 31, 2009 5:52 pm
as Rollaholic said,
run a tap down it & see how it comes out.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby fangsport » Thu Dec 31, 2009 9:00 pm
rollaholic wrote:if its the female section you definitely want to tap it before trying to put it on again.
HAHAHA my new sig!!!
fangsport
Postby Mr. Mainstream » Fri Jan 01, 2010 9:52 am
:lol: :lol: :lol:
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby evil_si » Fri Jan 01, 2010 2:20 pm
as said if its an internal thread run an intermediate tap down it,
being on the oil side of things you would want to isolate the part as much as possible and then flush / clean it throughly once you have cleaned the thread up
evil_si
