What is the diff ratio on a standard AE86 and AE85?
Postby matt dunn » Mon Jan 04, 2010 9:42 pm
Anyone know what the standard diff ratio is on an AE86 from factory,
or diff code from a build plate and I can work it out.
matt
Postby frost » Mon Jan 04, 2010 10:00 pm
4.1 and 4.3 depending on the model, gtapex was the 4.1 and gtv was 4.3 i think, the three apex diffs ive had have been 4.1 and the one gtv was 4.3
all looked as if they have never been cracked open, if i can find my build plates i'll post them,
Postby matt dunn » Mon Jan 04, 2010 10:04 pm
frost wrote:4.1 and 4.3 depending on the model, gtapex was the 4.1 and gtv was 4.3 i think, the three apex diffs ive had have been 4.1 and the one gtv was 4.3
So that would mean there are probably different speedo drive gears available?
Postby frost » Mon Jan 04, 2010 10:07 pm
not sure on that but gtapex was a digital dash so maybe there is a correction factor in it,
Postby matt dunn » Mon Jan 04, 2010 10:15 pm
Wonder what ratio's are out there for the AE85 S series diffs?
Postby frost » Mon Jan 04, 2010 10:21 pm
only silly 3.9
Postby l1ttle_d3vil » Mon Jan 04, 2010 10:23 pm
matt dunn wrote:Wonder what ratio's are out there for the AE85 S series diffs?
were there different series ae85 diffs?
I have two diff heads out of ae85s - no idea exactly what model/year, just know they're from an ae85.
pretty sure they're both different ratios, I can count the teeth on them if you want?
Postby matt dunn » Mon Jan 04, 2010 10:34 pm
Yeah if you could. may be keen to buy one if there's one somewhere near the AE86 ratio's.
mine is a 3.73 according to the build plate. S302 code.
Postby Mr Revhead » Mon Jan 04, 2010 10:39 pm
http://www.toyodiy.com/parts/p_J_198305 ... _3304.html
two p/ns there
if you can get a proper copy of the genuine EPC you could use the match off function to look for other options
Postby frost » Mon Jan 04, 2010 11:37 pm
3.73!!! holy crap thats a first, edit:oh wait that sound right, brain click,
85 is 3.7 early ae's are 3.9 ae86 is 4.1 & 4.3
Postby NZ_AE86 » Tue Jan 05, 2010 8:21 pm
Yep, there are. As far as I know you need to replace the metal drive gear that is splined to the output shaft and the drive assembly that holds the plastic gear.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby l1ttle_d3vil » Tue Jan 05, 2010 8:53 pm
matt dunn wrote:Yeah if you could. may be keen to buy one if there's one somewhere near the AE86 ratio's.
Mine is 3.73 too. Just remembered the other diff head was in my car when I sold it... :lol: That one made my speedo about 10km faster (at 100kmh) from memory though.
The one I've still got is completely pulled apart and has a couple of teeth missing too. Gonna chuck it though, so if you did want anything let me know.
Postby Truenotch » Tue Jan 05, 2010 10:24 pm
frost wrote:not sure on that but gtapex was a digital dash so maybe there is a correction factor in it,
Not all GTapex are Digi dash though...
Truenotch
Postby QikStarlie » Tue Jan 05, 2010 11:09 pm
have a diff hanging about in the garden here. will check the code on car tomorrow.
QikStarlie
