Brake pad suggestions, ae101
Postby kopfschuss » Wed Jan 06, 2010 8:55 pm
So, with doing a few trackdays and things in my trueno (92 ae101 non SS) and my pads running low I was looking at what brake pad options are available. I currently have some TRW (GDB232 part no) pads which were good, but then I dont really know any better. I looked to get some bendix ultimates, but it seems they dont make them for this car. What other options should I be looking at? for occasional trackdays/spirited driving etc.
Also whats a good fluid to use with them?
kopfschuss
Postby jakesae101 » Wed Jan 06, 2010 9:02 pm
mintex pads are good maybe 1144 pads look up 0800 racebrakes
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Brick » Wed Jan 06, 2010 9:08 pm
+1 for mintex
i run the race ones in my rally car, they bite good cold and ive never managed to cook them
Brick
I know Kung Fu
Postby kopfschuss » Wed Jan 06, 2010 9:14 pm
so just stick with the 1144 then and not the 1166? Ive generally been doing about 6 or 7 stints of 5 laps (+ warmup/down) during the trackdays, and maybe attend 2 or 3 a year?
What fluid do you recommend then?
Edit: this has been taupo track 1/4 so far.
kopfschuss
Postby Brick » Wed Jan 06, 2010 9:18 pm
If your not losing your brakes as in they're not getting to hot and pedal sinking etc stick with them. No point spending more for a pad if you dont need to
Dot 4 brake fluid is fine
Brick
I know Kung Fu
Postby kopfschuss » Wed Jan 06, 2010 9:23 pm
I ran out of brakes last time. Foot to the floor, no brakes at all till they lock up. Im not 100% sure if it was air or fluid boiling, but my pads need replacing soon anyway so might as well replace them with something decent. The TRW's I found good, was just seeing what other alternatives there are?
Actually both times ive had spongey brake problems by the end of the day, the first time though might have just been because the fluid was x amount of years old, I hadnt changed it since buying the car.
kopfschuss
Postby Brick » Wed Jan 06, 2010 9:34 pm
All depends on how much you want to spend,
I got top of the line mintex ones which retail at $320ish for fronts alone (twin pot evo brakes)
they should be more than enough for what you need. Maybe find the next ones down?
If your fluid is old then make sure you get fresh stuff
Brick
I know Kung Fu
Postby kopfschuss » Wed Jan 06, 2010 9:38 pm
I gave it new silverline 5.1 fluid last time but still managed to have no brake pedal by the end of the day. Can anyone else comment on the m1144 pad? by the looks of it the 66 is a bit extreme for my use, they seem to kill discss for road cars.
kopfschuss
Postby Dell'Orto » Wed Jan 06, 2010 10:29 pm
1144's would probably be the best bet, they're more of a competition pad than the TRW pads are. Have heard of people nuking them still! Perhaps look at TRD?
Postby kopfschuss » Wed Jan 06, 2010 10:34 pm
Hmm, ill see what price the 1144's come to then. If they are a definite improvement on the trw and a decent price ill go for them. I hate ot think what TRD pads would cost :/ .
kopfschuss
Postby kopfschuss » Thu Jan 07, 2010 5:28 pm
Wheres the best place to get the mintex pads from? does bnt do them? or just from racebrakes?
kopfschuss
Postby Brick » Thu Jan 07, 2010 5:45 pm
BNT, see if you can get them at trade cost 8)
Brick
I know Kung Fu
Postby kopfschuss » Thu Jan 07, 2010 6:05 pm
Ok cool, I think i know someone I can get trade through. Thanks.
kopfschuss
Postby Brick » Thu Jan 07, 2010 6:12 pm
If your in chch i could help
Brick
I know Kung Fu
Postby kopfschuss » Thu Jan 07, 2010 6:29 pm
Auckland sorry :(
kopfschuss
Postby mjrstar » Thu Jan 07, 2010 7:19 pm
Surprised no-one suggested carbotechs or endless as an option?
Also I rate motul RBF600 fluid as being up to the task..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Dell'Orto » Thu Jan 07, 2010 8:05 pm
Whats the cost like on Carbotechs? Have heard mixed things about Endless
Postby molex » Thu Jan 07, 2010 8:15 pm
Love my mintex 1166, I'm running AE101 brakes in my starlet, $250/pair from racebrakes. Running high temp fluid is very important! Pads can be as good as you like, if your fluid is boiling you're going to have a hard time. I was using penrite sin, great stuff if a bit pricey.
They will do just as many K's as a set of road pads doing a few track days a year, pretty excellent longevity. One significant disadvantage is how dusty they are, if you don't mind cleaning your wheels all the time then go for it!
molex
Postby kopfschuss » Tue Jan 12, 2010 8:59 pm
what fluid do you use molex, i was looking at penrite SIR dot4.
kopfschuss
Postby pc » Tue Jan 12, 2010 10:47 pm
I've run many brake fluids, all around the same temperature range, and all cheap. I have never had a fluid boiling problem. Changing fluid regularly is a good idea though.
If anything I would recommend a full race pad for better braking at the track, it has made the most difference in my car.
Although i've never used mintex 1166, i've seen them removed from other cars and they don't seem to wear well (crumbling), and they create hot spots.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
