Hey all, i'm running twin sidies on my 4age motor and have changed to an electronic distributor out of a 3a, it looks like these use the external igniter on coil setup . My question is has anyone done this arrangement as opposed to the internal igniter setup on theirs, and with powering up the distributor it has 2 wires 1 pink, 1 red, same with the igniter. So where do the wires connect on both the distributor and the igniter, does the dizzy use a wire off the negative to one wire but if so where does the other one go?
I haven't been able to find a 3au specific wiring diagram, just 4a corolla one which doesn't help me much due to 4a electronic setups all being internal igniter/coil
