oil return from turbo
Postby deaf_rattle » Fri Jan 08, 2010 12:06 pm
well i was looking at what to do today for my oil return.
I think its going to be too close to the exhaust manifold and i might have to get a hard line made up.
Is there any high temp hose solution for this? or is hard line the way to go?
Postby 1598cc » Fri Jan 08, 2010 12:15 pm
extend the oil return with some tube, weld to the flange - or tack weld it and use kneedit to seal if u dont want to possibly warp the flange
1598cc
Postby Crucible » Fri Jan 08, 2010 1:15 pm
1598cc wrote:extend the oil return with some tube, weld to the flange - or tack weld it and use kneedit to seal if u dont want to possibly warp the flange
wtf kneedit!!!!!!!!!????????????????????
may as well just use bubble gum lol
Crucible
Real Life Mechanic
Postby Bazda » Fri Jan 08, 2010 1:18 pm
You can do it in soft line but would need to use the heat sleeve that goes over it. Not the fire sleeve which is orange. Heat one is grey.
Postby 1598cc » Fri Jan 08, 2010 6:36 pm
yeh, maybe not the best idea.. does work tho
1598cc
Postby Crucible » Sat Jan 09, 2010 9:04 pm
suppose you have to make do with what youve got at the time...
Crucible
Real Life Mechanic
Postby Py7h0n » Sat Jan 09, 2010 9:44 pm
Hard line mate!
Py7h0n
