Fitted aftermarket seats to GTT?? Jamex Seats
Postby dakine » Fri Jan 08, 2010 7:39 pm
Hey
Has anyone brought some of those cheap jamex seats off trademe? they say they use universal fitment but I want to hear from people who have fitted any kind of aftermarket seat into a GTT and any issues they had etc...
Thanks in advanced,
Mark
dakine
Postby madaz-gtt » Fri Jan 08, 2010 7:58 pm
i fitted two of these to my old gtt. the problem i found was there was no brackets that could be bolted in that would fit the jamex rails and its heaps of work to get the factory rails welded on.
i got some brackets custom made but they made the seats sit high as so my head was touching the roof.
id recomend getting some custom brackets made up but get them set as low as possible or ull run into the same problem
good luck man, if you manage to get them in nicely please let me know as ive got another gtt know im wanting to put new seats in.
madaz-gtt
Postby WCKWGN » Fri Jan 08, 2010 8:49 pm
got corsa in my gtt
used factory rails. sits at mint height. needed longer seat belt stalks and re location so went thru under cert when car was done
WCKWGN
Postby matty_j24 » Mon Jan 25, 2010 8:11 pm
i fitted some kw seats into mine make your own custom rails and make sure you make them as low as possible or else your head will be touching the roof my rails have only a few mm clearance and id say they are probably sitting lower than factory seats then you also need to make some mounting points for your seatbelts you cant run any other seatbelts that i am aware of as they have plugs on them which hook into your airbags etc.
matty_j24
Postby Alex B » Mon Jan 25, 2010 8:54 pm
You need a cert because you have airbags also.
