st185 3sgte dead
st185 3sgte dead
Postby Boosted_162 » Sat Jan 09, 2010 4:25 pm
Well, i finally got the RC running again. Have had it idling up to normal temp on many occasions over the last 3 days. Went for my first drive up the driveway, and managed to hit boost. The ic pipes came off, which i was expecting and then the warning lights came on like the alt wasnt charging. Checked plugs and belt seemed fine.
Did up the ic clamps and tried again. Up the driveway was fine so thought id go up to the road. Went to take off, hit boost in first gear and felt like i hit boost cut or something. Look at tacho and car is stalled. Now when you turn the key absolutely nothing happens. No lights or anything. Wont jump start either.
So obviously ive $&#$% something up somewhere, and obviously is electrical. Main battery earth and chassis->motor earth seem fine. Have put the battery on charge.
Could the alternator/battery be at fault here? Or am i looking for something bigger than this?
Postby Adamal » Sat Jan 09, 2010 4:38 pm
Have you been able to push start it at all? Able to turn the engine over by hand?
Postby Boosted_162 » Sat Jan 09, 2010 4:47 pm
Adamal wrote:Have you been able to push start it at all? Able to turn the engine over by hand?
Yeah engine will turn with a rachet on the crank. Cant push start as our driveway is up a hill, and cant pull start as im basically here by myself and the swift probably cant pull the fat arse up the driveway :lol: :lol:
Postby iOnic » Sat Jan 09, 2010 7:27 pm
It's dead. $10?
Postby deaf_rattle » Sat Jan 09, 2010 7:45 pm
iOnic wrote:It's dead. $10?
Postby Sick Puppy » Sat Jan 09, 2010 8:00 pm
You fiend! How can you offer just $10 to someone in a time of great need?
[looks around]
$15? :P
Seriously, dumb question I imagine, but you've checked the fuses and connections, there are no melted wires/ smell of burning plastic anywhere? Any belts come off, or pulleys not fully attached?
Project thread here
Discussion thread here
Sick Puppy
Postby iOnic » Sat Jan 09, 2010 8:07 pm
Haha just taking the piss......and I can't beat $15 :lol: :P I've given Craig some suggestions on what to check.
Postby Boosted_162 » Sat Jan 09, 2010 8:12 pm
There was a very faint of something burning, but not sure if it was just some of the large amounts of liquid i spilt everywhere.
Am currently tracing through starter and alternator live feeds for shorts.
Offer me alot more than $15 and ill consider selling :lol: its only gunna be for sale when its all sorted anyway.
Postby Boosted_162 » Sat Jan 09, 2010 8:48 pm
Finally found my multimeter and did a bit of measuring. Found there was 12v at the battery, and like 0.6v at the starter. Think i may have found my problem... :lol:
Postby Adamal » Sat Jan 09, 2010 10:45 pm
Ahhh yes. Yes you have. I'm no mechanic, but I think that might be a tad under voltage :P
Probably a wire has burnt out if you could smell something.
Postby Boosted_162 » Sat Jan 09, 2010 11:01 pm
Adamal wrote:Ahhh yes. Yes you have. I'm no mechanic, but I think that might be a tad under voltage :P
Yeah sounds like it, gunna have to pull the loom apart and trace the wires. Least its not in a SW20!!
Postby Adamal » Sat Jan 09, 2010 11:08 pm
Thank GOD!
Postby levinguy » Sun Jan 10, 2010 12:05 am
yup you want 12 volts constant at the starter all the time.. i knew it was cursed but not cursed this much?!
levinguy
Postby levinguy » Sun Jan 10, 2010 12:24 am
i thought about it... i'll give you what you paid for it... :lol: 8)
levinguy
Postby Alex B » Sun Jan 10, 2010 1:24 am
What are the earths like before you go pulling looms apart.
Postby iOnic » Sun Jan 10, 2010 1:52 am
Problem is on supply side not earth side. The starter wire would have earthed out somewhere (probably ex manifold/block) and will be burnt out under the insulation. Quite a common thing.
Postby Boosted_162 » Sun Jan 10, 2010 2:00 am
levinguy wrote:yup you want 12 volts constant at the starter all the time.. i knew it was cursed but not cursed this much?!
Its not cursed, i am :lol: :lol:
levinguy wrote:i thought about it... i'll give you what you paid for it... :lol: 8)
Considering ive spent another $5-6k on top of that at least, i dont think so!
Alex B wrote:What are the earths like before you go pulling looms apart.
Earths were all good. Shouldn't effect the operation of ALL the electrics tho, i mean even the stereo doesnt go! Couldn't even put the window up again :lol: :lol:
Postby Malcolm » Sun Jan 10, 2010 11:02 am
have you checked the condition of the fuse box? On st185s it's not uncommon to have issues with the plugs going in under the fuse box.
I'm very suprised that you don't have 12v at the starter, the wire that supplies the starter comes straight off the battery and down to the starter, it's only about 300mm long and I don't remember it going near anything that would cook it. Being reasonably thick, I'd think you'd get a decent bit of a fire from it if it did earth somewhere too. That is of course, assuming you're talking about the power wire to the starter, and not the solenoid switching wire.
I think as a general rule you should always look at connectors, switches, fuses, relays etc before you start suspecting damage to the actual wiring.
Postby sergei » Sun Jan 10, 2010 12:03 pm
Fusible links? Checked those?
Postby MilfHunter » Sun Jan 10, 2010 2:51 pm
Sounds like the 30A, 40A fuses on the + terminal died
Do you have 12V at the ignition? Only other cause I can think of would be the master relay (next to the ECU) as it also switches power to the starter.
MilfHunter
