spark plug lead order URGENT
Postby 79rolla » Sun Jan 10, 2010 4:56 pm
hey.. this is a mitzi but someone must be abil to help me
long story short, im replacing the dizzy cap rotor plugs and leads, i have misplaced the old dizz cap witch i had written the positions of the leads on
its a 4g13
i know the fiering order is 1-3-4-2 like most 4cyl motors
im guessing it will be anti clockwise because the dizzy is positioned on the back of the head? would have guessed 1 at the top 4 at the bottem? have tryed with 2 and 3 on eyther side with no luck, could be because its been sitting for a while tho and battery is a bit flat..
the battery went flat wen i was trying to guess it so its on the charger now, i need this running tonite so my brother can take it back to hamilton
cheres for useull help!
past: AE82 FXGT
79rolla
Postby 79rolla » Sun Jan 10, 2010 5:00 pm
past: AE82 FXGT
79rolla
Postby iOnic » Sun Jan 10, 2010 5:52 pm
Turn the engine over by hand and see which direction the rotor turns. Get it up on the timing marks and whatever lead the rotor is pointing to = #1 and the next in the sequence = #3 then #4 then #2.
Postby 79rolla » Sun Jan 10, 2010 6:30 pm
iOnic wrote:Turn the engine over by hand and see which direction the rotor turns. Get it up on the timing marks and whatever lead the rotor is pointing to = #1 and the next in the sequence = #3 then #4 then #2.
didint relly want to do this because of the lack of room, but did. ended up pulling spark plug out and using screw driver to find tdc as there was no marks on crank pully :evil:
turns out 1 was on the back side, witch seems retarded to me.. but hey its mitsi...
so it looked like
--2--
1---4
--3--
oh well cheres anyway
past: AE82 FXGT
79rolla
Postby iOnic » Sun Jan 10, 2010 7:03 pm
Yeah it's a bit of a c**t to do on those motors :( So it's all sweet now?
Postby 79rolla » Sun Jan 10, 2010 8:16 pm
yeah its running now would give the timing a touch up but cbf with the lack of timing mark.. it doesint matter that mutch my brother just uses it for transportation.. been a few years scynce its last service... :roll:
past: AE82 FXGT
79rolla
Postby Adamal » Sun Jan 10, 2010 10:22 pm
Looks just like an SR20DE VVT dizzy cap....
