4age suzuki
4age suzuki
Postby mike-sj4age » Mon Jan 11, 2010 1:01 pm
Does anyone know what rwd gear boxs i can use with my 20v 4age?
mike-sj4age
Postby strx7 » Mon Jan 11, 2010 5:26 pm
use the SJ413 gearbox and put an adapter plate on it. I know of a super charged J20A going thru an SJ413 box, has never broken anything
Postby rollaholic » Mon Jan 11, 2010 6:12 pm
if you want to use a toyota box then a T50 from AE86 or similar will work. optionally you can get a W55 or similar and buy a bellhousing to suit a 4A from niteparts
dont expect much change from $1k for either option though
Postby mike-sj4age » Mon Jan 11, 2010 9:00 pm
any idea on how much an adapter plate would cost? and what would need to be done to fit the t50 thanks
mike-sj4age
Postby strx7 » Mon Jan 11, 2010 10:10 pm
make one out of some 8mm or 10mm plate
Postby rollaholic » Tue Jan 12, 2010 6:59 am
as long as the t50 has a 4A bell its a bolt up affair, they also came behind T series engines and probably some others so do be aware of that. as for fitting it to your suzi, i guess a custom cross member at a minimum and maybe some floor cutting depending on the shifter location
you might have to do some fiddling around with clutch slave etc too - does the suzi have a hydraulic clutch system?
Postby mike-sj4age » Tue Jan 12, 2010 8:16 pm
can i buy one without the 4a bellhousing then take the bellhousing off a stock fwd box and fit it up?
and its cable
mike-sj4age
