hiace gauges
hiace gauges
Postby 79rolla » Tue Jan 12, 2010 10:20 am
hey im having a bit of a problem with the gauge cluster on my perents hiace
for a little background iv just compleated replacing the head gasket, (witch a kunt but thats a diferent story)
and the motor was replaced a few months ago
scynce the motor was replacd the tacho hasint worked witch is no issue
but not its back togeather again the temp gauge sits on full the moment you turn it on, the fule gauge sits on empty and the tacho does nothing at idol but jumps way up in the rev range the moment you give it a few revs
the temp gauge drops when unpluged from the temp sensor and sits on dead cold with key on but not running
is there any comon problems that could cause this??
cheres
past: AE82 FXGT
79rolla
Postby NZ_AE86 » Tue Jan 12, 2010 1:01 pm
Missing earth will cause this. The cluster may not be getting its regulated voltage.
Check all your earth connection and anything that you unplugged during your repairs
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Postby gepsk8 » Tue Jan 12, 2010 1:28 pm
what injection pump you using old one or one on new motor? same with temp sender
O272754663
gepsk8
Postby 79rolla » Tue Jan 12, 2010 10:14 pm
same motor thatt was in it b4 head gasket blue but we didint chang the injector pump ect wen we swaped motors, hence the techo not working..
but its sorted out now, there was an earth wier not connected couming out of the loom so bolted that on and walah!! :lol:
confusing because there was still an earth from the block to the chassis but oh well its sused now
past: AE82 FXGT
79rolla
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
