BZG|Bling wrote:Hit the previous owner up about it and ask him how he unlocked it with a seemingly faulty drivers door lock.
celica_xr9145 wrote:I have a problem with the drivers side door lock on my 91 AE101 Trueno.
It has central locking so when i lock the car via the drivers side, the passenger side door locks aswell. (do you mean via the inside switch?)
Problem is that the drivers side door will not unlock (key doesn't even turn) which means to get in i have to unlock the passenger door and climb through and unlock it from the inside.
When i try to unlock the car via the passenger door, the passenger door will unlock but the drivers side door will still stay locked.
(does central locking work via th passenger door? ie can you lock it from passenger side)
You can lock it by using the drivers door and both doors will lock but can't unlock. (so switch won't unlock passengers door? or neither door will unlock via switch?)
Any ideas on what the cause of the problem will be?
I was thinking there was a loose cable but not so sure.
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
