TRD_ZERO wrote:I hooked the laptop to it and when i crank it over im getting 0 rpms and voltage drops down to 8v the back up to 12 when i stop cranking.
TRD_ZERO wrote:Turn it by hand, sorry to be a pain but could you elaborate a little more. Its a dizzy by the way. I hooked the laptop to it and when i crank it over im getting 0 rpms and voltage drops down to 8v the back up to 12 when i stop cranking.
Stu- wrote:TRD_ZERO wrote:Turn it by hand, sorry to be a pain but could you elaborate a little more. Its a dizzy by the way. I hooked the laptop to it and when i crank it over im getting 0 rpms and voltage drops down to 8v the back up to 12 when i stop cranking.
Sounds like the triggers are wrong to me. Remove the dizzy and spin it by hand, should hear the injectors switch. Pull the fuse to the fuel pump as noted above.
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
