Relays for twin headlights
Postby Dell'Orto » Mon Jan 25, 2010 6:02 pm
I'm in the process of converting my KE70 sedan to semi sealed headlights, and figured I should probably put relays in while I'm there.
It has the twin head light front, so my question is:
Do I need 1 relay for both low/high beams, or would I need a relay for each light?
Postby NZ_AE86 » Mon Jan 25, 2010 9:27 pm
Are you going to run single filament low beam lights or double?
Why do you want relays? You can end up with no high beam dash light if you wire them wrong.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
Re: Relays for twin headlights
Postby matt dunn » Mon Jan 25, 2010 9:48 pm
Dell'Orto wrote:It has the twin head light front,
Ok,
The big question is,
The inner lights which are normally high beam only,
the lights that you are fitting, what buld base do they take,
as if they are H1, H3 etc and earth through base of the light and frame etc,
then it is a real drama to do.
The Toyota headlights are double switched.
You ned to switch the power on and off to turn them on and off,
and switch the earths on and off to change beams.
Best thing to do is buy a pre-wired headlight upgrade kit if that is the case.
I had one in my old Ke70 roda car,
well worth it for a light upgrade.
Pulled it out when i sold it too, and possibly still have it.
Postby Dell'Orto » Tue Jan 26, 2010 1:32 pm
NZ_AE86 wrote:Are you going to run single filament low beam lights or double?
H4 lows, H1 highs. I figure a relay isnt a silly idea given the factory headlights would have been a 30w/40 sealed beam, and have now gone to two 60w low beam and 4 55w high beam (Thats how it works on H4's innit?)
matt dunn wrote:Ok,
Yeah using H1 high beams...sounds technical 8O
Postby NZ_AE86 » Tue Jan 26, 2010 9:38 pm
h1 bulbs = bugger! The fact (as Matt says) that they earth though the base doesn't make it easy, a little thinking is required and it's too late for that tonight! Maybe an extra relay for the inner lights.
Current rides;
1986 Levin GT
NZ_AE86
Postby gepsk8 » Wed Jan 27, 2010 12:09 pm
one relay on for high beam should be fine
O272754663
gepsk8
