Hilux diff in ke36
Hilux diff in ke36
Postby Josh » Mon Jan 25, 2010 8:12 pm
Would this diff fit a ke36 corolla, Its for a ke70 but are the diffs interchangeable between models?
http://www.trademe.co.nz/Browse/Listing ... =266759026
2tb kp60
Josh
Postby Dell'Orto » Mon Jan 25, 2010 8:38 pm
It'll fit, but at 1400 it'll make getting good offset rims in there hard
Postby Josh » Mon Jan 25, 2010 8:47 pm
Yeah, bit wide ay. Standard diff is 1360mm
2tb kp60
Josh
Postby QikStarlie » Mon Jan 25, 2010 9:42 pm
you need some rare rn25 axles, or get some shortened to get down to 1360mm. shortening the case itself is fairly easy.
making a 1400mm diff like in the auction is pretty easy. as you can just trim 1420mm axles
QikStarlie
