working on a 3sfe 4x4 caldina 1997, The fans wont switch off...
Relays fine... im sure its the fan temp switch(they turn off when grounding the light-green black trace switch wire)..... But I cant find the temp switch anywere.... only a guage temp and ecu temp senders
Does anyone know where the switch is or what switches them? might be the ecu? but cant find a pinout anywere for a 3sfe (its a later version with coil packs and toothed crank trigger)
