1998 Caldina Cabin Filter
Postby BZG Wagon » Sun Jan 31, 2010 4:21 pm
1) Did they come with them?
2) If so - where is it?
Took the glove box out and couldn't find one where the fan unit is. Took out the fan and it's caked in dust & leaves. Wonder is there should be a filter sitting inside it? Surely there will be a filter somewhere - under the bonnet where it draws outside air from possibly?
It's a GTT if that makes any difference.
Any ideas?
BZG Wagon
Postby fivebob » Sun Jan 31, 2010 4:35 pm
There are two of them according to the EPC, but I think they might be after the fan :?
Postby BZG Wagon » Sun Jan 31, 2010 6:17 pm
Hmm... I might keep looking then.
There are two padded flaps which open/close when fresh or recirculating air is selected, but I wouldn't have picked them as filters.
I gave the plastic fan a clean - it was disguisting. Thick black, dusty tar-like stuff came off & it stunk to high-hell.
Not sure if it was due to the previous owner being a smoker or just build up over the years (probably both).
BZG Wagon
Postby matt dunn » Sun Jan 31, 2010 8:33 pm
Only one's Ive ever seen have been after the fan,
and they are not very common at all.
had lots of dash's out and apart over the years, but not a lot of filters.
Have replaced heaps of fans motors that are jammed with leaves and burnt out though,
Postby 1hypo3 » Mon Feb 01, 2010 7:33 am
You wont find many in older vehicles but all newer cars have them
If you have a look there might be a flap just above the fan where a panel style filter could be housed if so there might a drawer to pull out and the filter sits in there.
1hypo3
