mr2 turbo shifter cable lengths
Postby gasman » Sun Jan 31, 2010 8:59 pm
planning on swapping in a turbo mr2 box in my mr2 but from what i can determine the non turbo shifter cables wont fit or they will but will move the shifter towards the right.
i have a friend that knows a guy that has a whole heap of cables lying around but doesnt know what they are from but says that toyota has some colour bands painted onto the shifter cables.
so does anyone know what colour i need or know what the actual differences are between the cables so that i could identify the ones i need?
also rumor has that i only need one of the cables, any one know which one?
"What can possibly go wrong?"
gasman
Postby Adamal » Sun Jan 31, 2010 10:30 pm
Hmmm.... I don't see why they should make a difference? It should only make a difference if the shifter points are further or closer to the shifter cable mounts on the gearbox (where they have the clips that hold them in place). If that were the case, you'd have an up/down issue as well.
Also, why are you going with a turbo box on an N/A? The gears are longer, so acceleration will be slower, just the top speed of each gear will be higher.
Postby dragonx » Sun Jan 31, 2010 11:14 pm
i cant remember which cable it is, but i can confirm that one cable is different, longer or shorter im not to sure.
i have to wonder about the box swap into a na as well? you wil need the half sharfts and everthing that goes with that, seems like a lot of work?
In the Land of Dunedin
dragonx
Postby gasman » Mon Feb 01, 2010 6:49 am
ill be doing a v6 swap which is why ill be using the E153. i got the drive shafts and hubs as well the last vital pieces for the swap are the cables and the shifter boot and the parts it clips onto.
gasman
Postby MR2BOY23 » Mon Feb 01, 2010 10:11 am
photog will know he's currently doing v6 swap
MR2BOY23
Postby Phothog » Mon Feb 01, 2010 10:01 pm
MR2BOY23 wrote:photog will know he's currently doing v6 swap
i am ... sort of, just awaiting for more money.
if i recall, the N/a cables are shorter... Turbo ones are longer.
im doing it into a Turbo SW, but for the short time i have an S54 & axels.
so i can dummy up something stupid on the E153.
but first i have to fix the chassie on the fooker.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby gasman » Wed Feb 03, 2010 8:02 am
Chris.
would you be able to measure them up?
the two measurements that would be needed are the distance from pin hole to pinhole and the distance between the clips on the external sleve of each cable.
i got a set of n/a shifter cables out of the car so can compare the measurements easily.
gasman
Postby Phothog » Wed Feb 03, 2010 12:38 pm
gasman wrote:would you be able to measure them up?
Ah... no sorry i cant measure my set, they are still in the car, im just getting all the bits ready before i pull it apart.
Cheers,
Chris
Phothog
