Mr Revhead wrote:the vvt pulley move different amounts don't they?
matt dunn wrote:Mr Revhead wrote:the vvt pulley move different amounts don't they?
Not according to spec's I found no.
Cam Timings - (AE101)Inlet Cam
IVO IVC
VVT <4400rpm 0° 70°
VVT >4400rpm 30° 40°
Cam Timings - (AE11)Inlet Cam
IVO IVC
VVT <4400rpm 5° 65°
VVT >4400rpm 35° 35°
So there is supposedly 5° difference in timing, but the same 30° of travel.
sergei wrote:Here what is actually different about ST vs BT cams:
They have locating pins for pulleys in different places, so if you use BT cam in ST you will also need BT pulley, or if you use ST pulley on BT cam, you will need to account for timing marks being off on the wheels.
The BT cams have cutouts in the lobes (lobes are narrower at peaks by ~ 1/3) while ST cam is normal looking cam.
The BT has slightly higher lift (supposedly).
Other than that they are same.
matt dunn wrote:sergei wrote:Here what is actually different about ST vs BT cams:
4400 rpm aside it makes no difference, maybe it should just be VVT on and VVToff,
And if the locating pins are in different places how come when I lock the cam into TDC position and swap pulley the marks on the pulley's end up in the same place.
I know the EXH one are identical as I can lay them on top of each other and the dowell pin and the timing mark line up,
but you cant se through the Intake one to confirm but it appears the same.
sergei wrote:
This is very interesting.
I should have tried this when I had a chance.
What it means, that there is no major difference in between them at all.
Apart from anecdotal evidence of lift being higher, and anecdotal 5 degree difference in timing.
85AW20v wrote:And isn't there a difference in belt teeth between ST and BT - by 1 tooth? If correct, what would be the reason for that?
AceSniper wrote:the vvt pulleys dont swap over... I made one with some force... bolting it down but was a %##@ to take back off...
The toda gear may have slightly bigger hole or more 0 shape rather than o
The pin in the can is very slightly offset more from the center than the other I think
Also think its the dowel on the cam thats located 5deg diffrent from st-bt timing, as toda sell a offset dowel to correct it when using their cams as they are silvertop castings and when installing in a blacktop with std pulleys you need this pin.....
Thats how I understand it....
frost wrote:yes that seems to be the way i read it, i got toda cams and need that dowel,
but at $35 + post its a bit silly for a 12mm peace of metal,
