I'm considering running a Garrett variable vane turbo (no wastegate) on a 4EFTE Starlet. Just wondering if there's anything I should consider that I havn't already (especially re: oil supply and drain) if anyone knows much about them. I like the idea and think it would work really well in this application. Just have to make sure I'm not missing anything....
Also not quite sure how I would increase the boost level on this set up.....any ideas? The vanes are controlled via a vacuum operated actuator similar to a normal wastegate actuator but there is no actual wastegate.
