Exhaust touching underbody, WOF issue?
Postby kim0663 » Sat Feb 13, 2010 9:32 pm
I welded up my exhaust off the car as I did it at home, with car on axle stands.
It's the oem soarer exhaust with like 4 mufflers at the back, 2 on each side.
Well... As to be expected the pipe was welded on a slightly wrong angle and mufflers are not level/parallel and one of the mufflers touch the underbody of the car.
Is this a wof issue? Need i grind it off and weld it again or is it not a wof issue?
Mr2 GT-S
330ci M
kim0663
Postby DexGT » Sat Feb 13, 2010 11:14 pm
I wouldn't bother fixing it cause of WOF issues , I'd fix it cause of the annoying noise it will make when you are driving 8O :(
DexGT
Postby XSDRIFT » Mon Feb 15, 2010 11:04 am
Yeah does it hit when you drive? Its not such a major I wouldn't think... although some heat shielding or wrap may not be a bad idea to be safe as it could get quite hot and pending what it was touching it could create a pocket of extreme heat.
XSDRIFT
Postby kim0663 » Mon Feb 15, 2010 12:45 pm
well it only rattles on idle.... lol
I'll just go give it a try, depends on the wof inspector then i guess 8)
thanks!
Mr2 GT-S
330ci M
kim0663
Postby DRFTIN » Mon Feb 15, 2010 2:12 pm
DexGT wrote:I wouldn't bother fixing it cause of WOF issues , I'd fix it cause of the annoying noise it will make when you are driving 8O :(
DRFTIN
Re: Exhaust touching underbody, WOF issue?
Postby allencr » Mon Feb 15, 2010 7:04 pm
kim0663 wrote:Is this a wof issue?
Don't know nuttin bout wof, but the strain it's putting on the pipes, welds, bolts & gaskets with every shake is likely to cause something to fail pretty soon.
allencr
