stolic wrote:If it doesn't need to be ali - I've seen some rather tidy setups that used the plastic fuel tanks that are used for outboard boat motors. you can get them in a range of sizes from about 10l to 100l some even have simple level gauge, and cos they are made to hold fuel and not go all "x-splody" I would assume they are pretty tough.
or if you want ali, just find some ali pipe and cap the ends
or link 7 D1 spec catch cans together
gasman wrote:stolic wrote:If it doesn't need to be ali - I've seen some rather tidy setups that used the plastic fuel tanks that are used for outboard boat motors. you can get them in a range of sizes from about 10l to 100l some even have simple level gauge, and cos they are made to hold fuel and not go all "x-splody" I would assume they are pretty tough.
those d1 spec cans arent 1L each, they are less than 1L from memory
