1977 Ke30 Charging
1977 Ke30 Charging
Postby true?no » Wed Feb 17, 2010 4:26 pm
What should my 1977 Corolla Ke30 battery be charging at when running?? is it around 14.2v?? at the moment is charging at 13.4V and when car is turn off its reading 12.4v and in the morning after sitting all night it reading 11.9 ish volts (keep inmind its got a mongoose 5 star alarm with central locking etc). cheers
true?no
Postby Bling » Wed Feb 17, 2010 7:47 pm
13.4v is all good, pretty sure my starlet used to charge at around that voltage.
Postby cat007 » Thu Feb 18, 2010 7:48 am
BZG|Bling wrote:13.4v is all good, pretty sure my starlet used to charge at around that voltage.
same. But I'm pretty sure 11.9 overnight is a little low?
How old and what size is your battery?
Postby matt dunn » Thu Feb 18, 2010 10:35 pm
13.4 is marginal.
13.2 is the actual voltage of a charged battery in theroy,
so 13.2 you can say is the boarderline.
However modern batteries need higher voltage,
and if you are having problems it may not be enough,
aim for more like 13.9 to 14.4v.
Check the voltage at the alternator B+ terminal with the earth on the alternator bracket and see what you get,
which will tell you how much you are loosing through the wiring.
