Idling a fresh engine.
Postby TRD_ZERO » Thu Feb 18, 2010 3:57 pm
Im wanting to idle my newly built 4agte to check for leaks and see if the fan comes on and whatever else. How long can i let it idle for before i actually take it out for a drive.
Ive been told i shouldnt let it idle but i dont want to take it for a drive incase of serious leaks and what not.
Previous:
TRD_ZERO
Postby sergei » Thu Feb 18, 2010 3:58 pm
couple of min. should be fine. Enough to find all the leaks.
Postby XSDRIFT » Thu Feb 18, 2010 4:10 pm
My suggestion would be to warm it up a few times before you take it out. Give the rings and seals a chance to sit right. You can always give it some light revs on the spot. I wouldn't be driving it had been warmed up a few times so everyhting can be sitting where it needs to before you leave the driveway.
XSDRIFT
Postby escortman » Thu Feb 18, 2010 4:52 pm
yeh from memory hold it around lik 2500-3000 for 10mins and ull find leaks etc
4x4 toyota blizzard offroader
escortman
Postby cat007 » Thu Feb 18, 2010 4:57 pm
Err - no
Idle it only long enough to check for leaks then DRIVE IT.
Don't labour it - but rings NEED pressure to seal - that's just how they work.
Don't thrash the living crap out of it - but don't nanna around!
Postby escortman » Thu Feb 18, 2010 5:02 pm
different engine builders different starting directions
escortman
Postby FANGIN » Thu Feb 18, 2010 5:03 pm
Start her up, take it easy till it warms up then take it for a moderate drive.
Just dont go any where you can't push it home haha
1998 AE111 Carib - For Sale!
1999 JZS161 GS300 - Tow Wagon
1986 FC3S - 410wkw Drag / Track Toy
FANGIN
Postby cat007 » Thu Feb 18, 2010 5:03 pm
http://www.mototuneusa.com/break_in_secrets.htm
I'm not saying that idling or low revving wont work - but you'll get better results if you do the above.
Re: Idling a fresh engine.
Postby allencr » Thu Feb 18, 2010 5:04 pm
TRD_ZERO wrote: How long can i let it idle for before i actually take it out for a drive.
As long as you want, but keep it up a bit, 15-2000, so the cylinders & rings get a lot of lube thrown at them.
allencr
Postby mjrstar » Thu Feb 18, 2010 5:41 pm
As said above DONT let it sit at a low idle when new.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cat007 » Thu Feb 18, 2010 5:44 pm
mjrstar wrote:As said above DONT let it sit at a low idle when new.
+1
if you're too worried about driving it, at least put a zip tie or something on the throttle so it revs to about 2000-2500rpm while you're looking for leaks etc
Postby frost » Thu Feb 18, 2010 9:07 pm
the rings dont need revs, they need load to bead in, drive it like you stole it after you check for leaks,
Postby sark.inc » Sun Feb 21, 2010 6:44 pm
mmmm.. i am a tad scared to run mine in like i stole it D:
sark.inc
Postby Bling » Sun Feb 21, 2010 7:08 pm
I'll do it :lol:
Postby gasman » Sun Feb 21, 2010 8:34 pm
break it in on the dyno
"What can possibly go wrong?"
gasman
Postby Dell'Orto » Sun Feb 21, 2010 8:44 pm
Or find some hills and take it for a strop over them :D
Postby stolic » Sun Feb 21, 2010 9:20 pm
Dell'Orto wrote:Or find some hills and take it for a strop over them :D
I thought this was just general operating practice, not just limited to running in motors :D
stolic
