Running issues
Running issues
Postby TRD_ZERO » Wed Feb 24, 2010 6:07 pm
Ok so i took my car down the road for a drive for the first time. Idles ok not the best but when i start accelerating it seems like its struggling i almost cant even get over 4000 revs its starts spluttering boost pretty much only reaches .2 bar . Acceleration just isnt smooth. Seems to be running really rich still. After driving it down the road and back revs just wouldnt hold on their own it just kept dying unless i hold the revs.It like there is a vaccum leak. What other vac lines are there apart from the abvious 5 that you can see on the top am i missing one?
i had it idling with bliping the revs and the fumes were burning my throat.i installed a resistor pack but its stilll running rich. how do i check if it working correctly what readings should i be getting?
Blacktop turbo with g3
Previous:
TRD_ZERO
Postby gasman » Wed Feb 24, 2010 9:10 pm
you plugged in the laptop and checked to see everything is within spec?
check trigger errors theres a column with error numbers when you do data logging i think
"What can possibly go wrong?"
gasman
