turbo 4agze in dx not boosting?
Postby DFECTED » Fri Feb 26, 2010 9:19 pm
idles and revs at idle fine but when you try drive it, when its under load or sees boost it cuts out and has a meer of a time (~3,000rpm) , running 4agze loom, map sensor and ecu.
Im thinking faulty map sensor or fuel pump/ pressure issues.
Just wondering if this might be a common fault?
Thanks
DFECTED
Postby Mr Revhead » Sat Feb 27, 2010 8:41 am
Checked fault codes?
There a re few faults that throw a code and deny boosting
Postby DFECTED » Sat Feb 27, 2010 12:22 pm
Nope, how do i check fault codes when its a engine conversion and no engine check light
DFECTED
Postby Mr Revhead » Sat Feb 27, 2010 12:42 pm
Maybe by finding the CEL wires and hooking them up to a bulb.
If your loom allows it....
