3sgte Oil pumps
3sgte Oil pumps
Postby CelicaGT8 » Sun Feb 28, 2010 9:14 pm
Just went for a blat in my corona, ran the bearings, :evil:
Highly pissed off
Crank all measured etc, and acl race bearings, but i think it may have been the oil pump that created the problem as they do have a ton of problems.
Gen2 3sgte with gen 1 block (gen 2 oil pump)
Question:
Is there a better oil pump i can run? is there a trd option, what is recomended for race?
CelicaGT8
Postby frost » Sun Feb 28, 2010 11:45 pm
late model 5sfe pump,
Postby Akane » Mon Mar 01, 2010 3:33 pm
You can always shim the factory pump.....
Re: 3sgte Oil pumps
Postby B_giB » Mon Mar 01, 2010 4:09 pm
CelicaGT8 wrote:Just went for a blat in my corona, ran the bearings, :evil:
Highly pissed off
Interesting, A friend of mine had the same problem last year with his WRX, 800km into run in and it ran a bearing. Running ACL bearings too. Maybe a potential problem with ACL?
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby kim0663 » Mon Mar 01, 2010 4:58 pm
wouldn't it be the builder instead of blaming innocent parts?
builder's fault for not checking clearances etc
builder's fault for assembly of dirty components etc etc etc?
this is a question.
Mr2 GT-S
330ci M
kim0663
Postby Dell'Orto » Mon Mar 01, 2010 5:57 pm
Yep would certainly look toward engine assembly rather than bearings!
Postby Mr Revhead » Mon Mar 01, 2010 6:29 pm
kim0663 wrote:wouldn't it be the builder instead of blaming innocent parts?
this is a question.
Add not checking the parts properly
NEVER assume the part is correct and perfect. Check it.
Postby fivebob » Mon Mar 01, 2010 6:33 pm
Fresh rebuilt engines that have bearing failure how unusual :lol:
All joking aside I wouldn't be blaming the oil pump for such a failure until you eliminate everything else.
Remember, check twice fit once and clean, clean, clean is the proper way to build engines.
Postby CelicaGT8 » Tue Mar 02, 2010 10:40 pm
The engine recos polished and measured the crank, acl race bearings, correct torques, good oil
Did not use new pump. did use remote oil filter ..... to much pipe? 1.5ish meters.... long way for oil to travel...
Will pm frost about other pump
CelicaGT8
Postby CelicaGT8 » Thu Mar 04, 2010 10:51 am
what model 5sfe pump do i need?
CelicaGT8
Postby sergei » Thu Mar 04, 2010 4:44 pm
Why do you think there is inherit problem with oil pump on 3SGTE?
Perhaps your old pump is just out of spec?
Why not just get new oil pump for the engine in question?
Most failures I have seen were not because oil pump not supplying enough oil as the cause of the fault, but oil pump not supplying enough oil either due to blocked strainer or low oil level and cornering.
How much oil do you put into your engine? Have you accounted for extra oil in the lines (that drains into sump fairly quick)?
On cold, with remote oil filter and cooler, it should read above F line.
Postby iOnic » Thu Mar 04, 2010 6:00 pm
Just get a new TGP oil pump. I'd place good money on the failure being due to the fact that your oil pump was old/shagged and not replaced (when it should have been) as opposed to an inherent problem with the 3SGTE oil pump.
Postby CelicaGT8 » Thu Mar 04, 2010 10:52 pm
So there isnt a higher flowing pump avalible?
Have had tons of problems with 3s engines running bearings.
I used a new pump in the old housing, probably should have got a new housing too...
plenty of oil in sump, about 5mm overfull on the dip stick.
CelicaGT8
Postby bluemaumau » Fri Mar 05, 2010 10:19 am
CelicaGT8 wrote:Have had tons of problems with 3s engines running bearings.
what are you doing exactly with this car?
maybe try baffling the sump
Postby CelicaGT8 » Fri Mar 05, 2010 11:02 am
Well i live about 5 mins from a gourge...
CelicaGT8
Postby RBPOWA » Fri Mar 05, 2010 12:43 pm
i drove through that gouge perfectly fine without running my bearings :lol:
1989 Nissan Laurel
1989 Nissan Laurel
RBPOWA
Postby iOnic » Fri Mar 05, 2010 12:53 pm
Hunua Gorge? My 3SGTE did it's bearings in just coming out of there :lol: Definitely get a baffled sump.
Postby levinguy » Fri Mar 05, 2010 1:11 pm
iOnic wrote:Hunua Gorge? My 3SGTE did it's bearings in just coming out of there :lol: Definitely get a baffled sump.
eek, that is my 3sgte testing grounds. :evil:
levinguy
Postby strx7 » Fri Mar 05, 2010 1:36 pm
you hit the nail on the head.
Postby CelicaGT8 » Sun Mar 07, 2010 12:04 am
can conferm today after removing oil pump that the pressure relief piston in the pump housing was jamed sideways,
Iv hurd that this is due the different expantion rates between the materials...
Have seen it a few times before
CelicaGT8
