rear calliper rebuild
Postby bluemaumau » Mon Mar 01, 2010 6:44 pm
ae101.
ive started taking the callipers off and i was going to get them acid bathed... assuming the rubber seals are out can anyone see any issues with this?
the handbrake assembly will still be intact, with just the piston removed.
Postby bluemaumau » Mon Mar 01, 2010 7:04 pm
just realised one of the seals in the rebuild kit is a o ring in the handbrake assembly. so i need to take that off now i guess.
i assume i need a special tool to take the tension off the spring.?
Postby Bazda » Tue Mar 02, 2010 8:26 am
no, should be able to take it apart.
Postby bluemaumau » Tue Mar 02, 2010 8:44 am
okay cheers barry
Postby bluemaumau » Wed Mar 03, 2010 8:17 pm
what do people use to get the circlip behind the piston...? ive been to 3 specialist places and none have the right tool?
does anyone have anything i could borrow?
Postby Rick » Wed Mar 03, 2010 9:17 pm
Yeh I got a tool for inserting the circlip, I had a sh!t of a time trying to do it without it.
Postby bluemaumau » Thu Mar 04, 2010 10:07 am
awesome anychance i could come out to yours tonight man?
ill send you a pm
