Rear Caliper with Hand Brake
Postby nz_climber » Tue Mar 02, 2010 7:44 pm
Hi everyone, just looking for a rear brake caliper ideas for my Lotus 7:
What I need is
Caliper with intergrated handbrake on the caliper
Fit about a 250mm disc (about 10mm thick) size can vary but don't want to go to big.
Small, Compact and light.
And fingers crossed they don't cost the earth, looking for something that is fairly common so I can get pads etc.
So what production vehicles should I be looking at? Anyone got something laying around that they don't need?
Any help would be great
Aaron
nz_climber
Postby fangsport » Tue Mar 02, 2010 8:00 pm
Primera, 323 Astina, are what i have been using.
the pad isn't overly large, so may affect outright braking even with a decent compound?
fangsport
Postby nz_climber » Tue Mar 02, 2010 8:13 pm
Don't need a big pad area, will probably be over braking the rear anyway. Cheers for the options, do you have any pictures etc of the calipers?
Edit: Anyone have any pictures of SW20, AW11 and MR-S calipers? would they work?
nz_climber
Postby Rick » Tue Mar 02, 2010 8:17 pm
I used AE92/AE101/AE111 rears on my AE85.
Postby RomanV » Tue Mar 02, 2010 8:33 pm
Yeah SW20 rears can accomodate a fairly decent sized disc.
Postby thegreatestben » Tue Mar 02, 2010 8:33 pm
SW20 Later model calipers are decent.
I am using them on my aw11, which are mated up to the factory front rotors.
thegreatestben
Postby fangsport » Tue Mar 02, 2010 9:44 pm
Rick wrote:I used AE92/AE101/AE111 rears on my AE85.
now that you mention it, i think AE82/92 are on my TE71 clubcar.
NZ_climber, i can em-ail some pictures tommorow. i am about to have a big clean out in that dept of shed, so if they suit your application, i am open to covering freight and some beer money :wink:
fangsport
Postby mjrstar » Tue Mar 02, 2010 10:00 pm
also evo 1-3 or series 4 rx7 are pretty good.. i run the rx7 ones on the rear of my starlet.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cedwards » Tue Mar 02, 2010 10:31 pm
What does the altezza use? Is it the same as caldina with the drum brake/disc brake combo? or purely disc brake.
cedwards
Postby nz_climber » Tue Mar 02, 2010 10:42 pm
Altezza use the drum inside the disc set up.
nz_climber
brakes
Postby panda_dan » Fri Mar 05, 2010 2:39 pm
Cheap and cheerful setup for me: hilux diff + rps13 nissan discs and callipers with ae86 cables. Works a treat. Diff weighs a ton though so if you're making a lotus which relies on light gear, and presuming your power wont be through the roof, you could buy a nice ae86 set up all ready to go ex japan with trd lsd already in there for about 1.5k
panda_dan
Postby nz_climber » Fri Mar 05, 2010 7:12 pm
Cheers, but already have a diff etc, running a IRS set up with sierra diff (alot lighter than other options) and currently have sierra drums, but want to switch.
those ae82/92 calipers seem to be the best option at the moment, just waiting for some more info etc on them.
As for power, its got a Beams 3sge, so more than enough in a 600kg car!
nz_climber
