TRD_ZERO wrote:yes both blacktops with quads. Map sensor is from the only vac line on the far left.
sergei wrote:TRD_ZERO wrote:yes both blacktops with quads. Map sensor is from the only vac line on the far left.
You mean the one is used for pressure regulator?
That is worn place.
There is another vacuum point - it comes from middle just below PVC line.
TRD_ZERO wrote:you mean i should grab the map signal from the little vac line just between the cam cover and throttles. U think not having it there could cause this issue of mine?
TRD_ZERO wrote:Well im hoping that is the case. What other vac lines are there? I want to make sure i have them all covered. There is another one on the throttles to the left on throttle #1 then a cluster of three on the right on throttle #4. Is there any others apart from these 5?? Im just trying to eliminate leaks. Also im not running an oxy sensor could this be adding to the mess? As i understood it the oxy sensor was only really needed when getting tuned.
TRD_ZERO wrote:Ok ill give that a run when i get home.
It has been over fueling quite abit when i was doing the tests and i popped the oil cap off and the oil smelt like fuel. Ive had the cap off for over a week hoping if some fuel had gotten into my oil it might evoporate. Should i be concerned or what should i do?
TRD_ZERO wrote:I swaped the position of the map sensor vac line and gave it a start up, the car idled but i was getting a howling noise out of the engine bay. the pipe that was connected to the pcv valve was causeing massive vaccume and when i just touched it the car died. what do i do with this pipe do i just block it off?And when i did have it plumbed into the pcv valve i was getting air comming out of the nipple on the cam cover by the dizzy. This could all have been a big vac leak causing it to run rich. No?
