Help with choosing a new clutch
Postby Emz » Thu Mar 04, 2010 9:06 pm
I have a car. It has a clutch. But now it needs a new clutch.
I want to use it for weekend driving and drag racing.
In the next couple of months I am going to have some extensive modifications resulting in approx 560rwkw.
Can anyone give me any ideas or point me in the right direction to find a clutch to handle the new power and the stress of drag racing but also allow me to drive it nicely on the streets. I am only little and don't want a mega hard out clutch :)
'97 Supra RZ - Click Here! | Discussion thread - Click Here
Emz
Miss Supra Princess
Postby eskimo » Thu Mar 04, 2010 9:31 pm
Could go with an Exedy twin plate clutch. Haven't found these to be hard om the left leg
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Dell'Orto » Thu Mar 04, 2010 9:31 pm
You dont really have much option I'm afraid, you'll have to go multi plate clutch to be able to contain the power and handle the abuse.
That said, a good twin plate clutch is not actually that bad to drive, but they are noisy. Probably a softer pedal than a single plate clutch with a massive pressure plate!
Postby tomtom » Thu Mar 04, 2010 9:32 pm
5 puk exedy wud b mint.. 8)
TRUENO gtz! AND 1UZ MANUAL SOARER!
tomtom
Postby Dell'Orto » Thu Mar 04, 2010 9:35 pm
5 puck exedy would die within a week with 800+hp
or more correctly, the 8 zillion ft/lbs of torque that it would produce
Postby Emz » Thu Mar 04, 2010 9:46 pm
What do we think about the TRD twin plate race clutch?
Emz
Miss Supra Princess
Postby Dell'Orto » Thu Mar 04, 2010 10:18 pm
Is it still available?
Postby Akane » Fri Mar 05, 2010 4:09 am
You don't have a choice, with that much torque you need a heavy clutch.
with 560rwkw you might even need to go one step higher.
I'm thinking ORC carbon clutches.
Postby IH8TEC » Fri Mar 05, 2010 8:31 am
Emz wrote:What do we think about the TRD twin plate race clutch?
talk to audiman, john, he'll advise you well with those power levels.... or look what the guys in the states run
Postby deaf_rattle » Fri Mar 05, 2010 2:40 pm
isnt he running an auto now?
Postby cat007 » Fri Mar 05, 2010 2:48 pm
John's running a TH400 now. Not really very practical when it comes to a daily driver.
Dell'Orto how the heck is a clutch "noisey"?
Postby iOnic » Fri Mar 05, 2010 2:57 pm
Multi plate clutches rattle when disengaged. Very embarassing when you pull up at a set of lights and people tell you there's something wrong with your car :oops: (as if you can't hear it)
Postby gasman » Fri Mar 05, 2010 3:01 pm
Fidanza started making twinplates with light springs that hold the plates lightly together when the clutch is disengaged to reduce the noise.
"What can possibly go wrong?"
gasman
Postby Dell'Orto » Fri Mar 05, 2010 5:50 pm
cat007 wrote:John's running a TH400 now. Not really very practical when it comes to a daily driver.
Like iOnic said, the plates rattle. Sounds like a really rooted release bearing :lol:
The Fidanza clutches look to be quite good value too, could proably get a price on a twin/triple plate.
Postby Bazda » Fri Mar 05, 2010 6:38 pm
The teeth design twin plates like mine rattle.
The V design ones you can barely hear.
If you get the correct size release bearing to suit the presure plate exactly then usually it would be a nice soft pedal, or go with a hydraulic releas bearing.
Nitro and V8 Killer dont run twin plates, they are still on single plate clutches and daily drive them. Might be worth approaching them at the next night speed drags..
Postby tomtom » Sat Mar 06, 2010 1:20 pm
it was a joke...not much humour on here sometimes..matty got it tho.x
tomtom
Postby strx7 » Sat Mar 06, 2010 4:49 pm
Ring Autoclutch and tell them what you have, want you want to do etc etc etc and they'll recomend what they believe to be the best set up for the job.
Postby bluemaumau » Sat Mar 06, 2010 5:40 pm
everytime someone asks about clutches most people say talk to autoclutch
Postby Emz » Sat Mar 06, 2010 6:04 pm
Sweet, have emailed autoclutch
Emz
Miss Supra Princess
Postby matt dunn » Sat Mar 06, 2010 9:25 pm
gasman wrote:Fidanza started making twinplates with light springs that hold the plates lightly together when the clutch is disengaged to reduce the noise.
That would be the same idea that they have in the Turbo Falcons,
that required all the cars to be recalled and held for a few months while they designed a new clutch for them.
